Thread: BallNuts, 1,2 or a double.
Hello,
in my quest to get going on my lathe conversion i've been having a bit of a look at various ballnut sellers and have been left with some questions.
i'm looking to get as low a lash as is possible without going to bonkers on price :)
How many nuts should be used?
i see that some people use 2 non preloaded nuts with springs to preload between them,
then theirs the preloaded nuts(ones that are labled that way are much pricier)
and the double ball buts(2 seperate nuts packaged together and preloaded).
i have noticed that all the china sourced ball screws and nuts are a bit vague on their backlash specs, what sort of backlash should one expect due just to using a c7 roled ballnut of chineas origin?
Are the pre loaded nuts actualy naturaly backlash free in use?
The double nuts in a single package, beter value than 2 singles and making some sort of preload mount?
Ball returns, plastic tubes, external metal tubes or end circulation? Whats the deal, any difference or just cosmetic/down to space requirements?
Hope i'm not asking too many basic questions but i had a look at zap automation and they carry loads of different types of ball nut with little info for the noob on what makes them different(also many have very similar prices so that makes it even more confussing :)
Stuart
p.s. I found a referance to an faq on this site about stepper choice but i havn't been able to find it using the search box.
04-01-2015 #2
Backlash not really a problem on lathe as you're always approaching cut from same direction, so I wouldn't get carried away on this.
04-01-2015 #3
I'm trying to do a geometric capable build, so am interested in it being fairly low.
I can always limit it to plain turning if it doesn't work out well. :)
Stuart
04-01-2015 #4
The cheap double nuts are shimmed so the low backlash quoted lasts until it beds in.
Springing nuts is a right royal pain in the backside but if you have gone anal on backlash then you don't really have an alternative.
04-01-2015 #5
Ok so the pre-loaded ones arnt adjustable to take up ware in them?
(sorry if thats a dim question)
Stuart
04-01-2015 #6
I may be out of date, been a few years since I bought ball screws.
You can fit oversize balls, that really stiffens them up, but nothing I know lasts, except springs.
04-01-2015 #7
I have a Chinese 12 mm ballscrew on my S7 cross slide, single nut and IIRC the backlash I measured when first installed was about 0.03 mm, 30 microns. My Novamill has about the same value using double nuts on 16mm screws, but that has had a lot more use! On a lathe it's nice to have low backlash if you want to do profile turning though would have to turn compensation on. I have tried compensation on the screws before but it doesn't work very well if the backlash is too large. In fact I found it didn't work at all!
06-01-2015 #8
Thanks for the info on backlash amount's that you guys have experienced, always nice to have an idea of what is achievable.
With regard to the preloaded nuts (either springs or balls oversized) is their any rule of thumb for the added drag/resistance in the system?
Stuart
1605 ballnuts
By dudz in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 30-03-2013, 09:31 AM -
Securing and Aligning Ballnuts
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 29-09-2012, 11:39 PM -
Ballnuts
By Web Goblin in forum General DiscussionReplies: 19Last Post: 04-08-2011, 11:28 AM -
Single or double??
By Wobblybootie in forum General DiscussionReplies: 7Last Post: 06-01-2011, 08:08 PM -
What oil for ballnuts?
By Robin Hewitt in forum General DiscussionReplies: 1Last Post: 24-10-2009, 08:36 PM
