    belt on belt/servobelt.
    Does anyone have any direct experience of using this system?
    I am looking to build a machine based on this principle.
    I will have an 8000mm Y axis and a 1600mm X axis gantry.
    The machine will be for fabric cutting so light duty and either a tangential pizza wheel cutter or gantry mounted co2 laser, but either way not heavy loads.
    It will need good rapids- 0.5-1.0 meters per second.
    I am erring towards a tractor belt small loop acting on a glued down base belt rather than 2 full length belts. Seems silly to use twice as much belt as i need.
    thanks for your help!
    Does that mean it acts like rack and pinion? G.
    Yes
    http://bell-everman.com/products/lin...elt-linear-sbl
    that is a link to the commercial version. belt stretch is limited to the amount of belt it takes to mesh with the bottom "rack" and go over the pinion so it should greatly improve a belt system. zero backlash apparently?
    Kind of hoping someone else has done this system and can warn me of the pitfalls ... but if not.. ill do it and report back.
    I built a prototype, but never tried it out. I decided to re-design it to be stronger and handle more power.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I am looking at using a servo-belt at the moment, could you give any pointers as to how you designed this.
    John
    Quote Originally Posted by johnsattuk View Post
    John
    Here are some pics
    http://www.cnczone.com/forums/linear...tml#post933535
    http://www.cnczone.com/forums/linear...tml#post934595
    http://www.cnczone.com/forums/linear...tml#post969827
    Gerry
  7. The Following 2 Users Say Thank You to Ger21 For This Useful Post:
  8. #7
    What belt you would use? T5 or HTD5?
    Have you considered to cast the belt on the frame side from epoxy resin?
    Quote Originally Posted by matthewb View Post
    If it is a horizontal drive, the full length belt is very good at keeping the base belt clean
    John
  10. #9
    John
    yes good point, im probably going to have the belt teeth vertical ..... probably... but that is yet to be decided 100% so.....
    Thanks Ger21, i will look through at your system
  1. Which Belt Profile
    By manofgresley in forum Belt Drive, Pulleys & Timing
    Last Post: 27-09-2013, 12:54 PM
  2. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  3. Belt Driving your leadscrews !
    By Lee Roberts in forum Lead Screws, Nuts & Supports
    Last Post: 05-02-2011, 09:14 AM
