    Hi Folks
    After many hundreds of hours machining aluminium and plastic we need to replace the Delrin nuts on the X and Y axis of our little Chinese 3020 CNC machine.
    Anyone on the forum know if or where these can be obtained?
    Hugh
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,915. Received thanks 227 times, giving thanks to others 775 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    What type of screw is on these ?
    .Me
    Hi Lee
    I think its an acme threaded screw although I have seen them referred to as trapazoidal (I dont know what the difference is! lol) and sized as 12x3, if that helps! :)
    Hello,
    Have a look on ebay as i know there is one seller in the UK that has them for sale in dif combinations, I know for sure they do the same screw and a matching Tap, so you could make your own if you wanted to buy the Tap? I do have a ACME tap but i dont think its the right size will go and have a look now...
    EDIT:
    Try contacting this seller: Trapezoidal ACME Leadscrew & Nut - TR8x1.5 TR10x2 TR12x3 TR16x4 - 3D Printer CNC
    They may be willing to sell you just the nuts :).
    .Me
    .Me
    You tried contacting the original seller? they usually stock spares.
    https://emvioeng.com
    What diameter do you need them? I've got a 12 x 3 tap and some 25mm black or 30 (something) mm delrin rod so could make some for you?
    Neil...
    Build log...here
    Have you had a look at this thread on making your own. I'm about to try making delrin nuts for my Chester 16v mill using this technique
    http://bbs.homeshopmachinist.net/thr...s-the-easy-way
    ​As far as i can determine, delrin and acetal are pretty similar (maybe delrin is just a trade name for acetal ?)
    Tom, don't!
    the forces on the chester are much larger than on the 3020. Stick with your ballscrew idea and use backlash comp in Mach3/4
    Hello,
    EDIT:
    .Me
    Many thanks for the link Lee! Will give them a bell and see what happens. :)
    Quote Originally Posted by komatias View Post
    Thanks komatias but i was hoping to optain them reasonably quickly, hopefully before our "bodge" falls apart
  1. Delrin Lead nuts.
    By Kammo1 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2016, 08:36 PM
  2. 3020 / 3040 / generic chinese router accuracy
    By m_c in forum Machine Discussion
    Last Post: 24-07-2014, 11:54 PM
  3. Yet another Chinese 3020 CNC upgrade thread!
    By Pointy in forum Machine Discussion
    Last Post: 18-02-2014, 01:04 PM
  4. My first bits of work from a chinese 3020 cnc
    By Jester in forum Woodworking Project Showcase
    Last Post: 02-02-2014, 12:08 PM
