    I want to use the spare parts from my x1 mill and need to cut some 55 degree dovetails but I have only seen 60 and 45 degree cutters are others available or will it be easier to cut with slitting saw etc.
    peter
    One slight problem.
    If that's a 1 1/2" cutter then the shank is 3/4" or 7/8" judging from the picture.
    A tad on the big size for a MT2 collet on an X1 :heehee:
    Slitting saw or use a 45 degree cutter and do two passes, one at vertical and one at 10 degree tilt.
    John S -
    No I only have the x1 mill.
    I want to machine a new base si I can use my spare parts on my drilling machine as it would give me a x-y table.
    I may get that 55 degree cutter and turn the shank down to 1/2" dia.
    Cheaper than the £40 found on the net.
    peter
    You won't turn the shank down it's solid HSS.
    John S -
    I thought you could turn hss using carbide insert cutters, I'm sure I've done it before.
    Peter
    Peter,
    I'll check in the morning to see what I have.
    I did have one reground once for a weird Taiwanese mortiser but I reckon it was 65 degrees.
    Anyway I'll still check and if I have one you can borrow it.
    John S -
  1. fly cutter advice please
    By luke11cnc in forum Tool & Tooling Technology
    Last Post: 07-12-2014, 01:38 PM
  2. Stepper controller to manually input a specific degree
    By Web Goblin in forum Motor Drivers & Controllers
    Last Post: 13-10-2013, 05:47 AM
  3. 45 Degree and round-over bits?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 05-05-2012, 04:13 PM
  4. Which Plasma Cutter to buy?
    By AndyG in forum General Discussion
    Last Post: 02-12-2011, 09:34 AM
  5. cutter for MDF
    By deannos in forum Tool & Tooling Technology
    Last Post: 16-10-2011, 09:33 PM
