30-07-2015 #1
What is the normal procedure on a lathe with an autochanger for tools, as far as head position and tool offsets are concerned.
I'm trying to get my head around programming a TCL160 for use with a Planet-CNC board.
As the tools stick out of the turret quite a way, I need to send the turret to a known safe location before rotating the turret to load a new tool.
At the moment, this is working fine, but when I activate the gcode tool selection command eg T3, the head moves to take up the newly offset position.
I can see that the lathe needs to enforce this offset at some point, but I'm surprised that it is when the tool is selected, and not at the next movement command.
When would Mach3 or Eding enforce the tool offset ?
Adrian.
31-07-2015 #2
You could write an line in the M6 macro to send the tool post to the home position.
It could lock like:
G53 G0 x0 assuming machine 0 is home to retract the tool in the x directionhttps://emvioeng.com
06-08-2015 #3
Unfortunately, the G53 command doesn't work at the moment :(
Adrian
WANTED: Wanted: Boxford 160 TCL CNC Turning Machine Tool Installation & User Manual
By Saracen in forum Items WantedReplies: 5Last Post: 26-01-2024, 10:18 AM -
Machine tool transporters that will move machines into position
By komatias in forum Marketplace DiscussionReplies: 6Last Post: 09-08-2013, 07:27 AM -
Mach3 Tool Change Position
By Mad Professor in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-07-2013, 06:54 PM -
CNC Rotary table/lathe head indexing
By Kwackers in forum Electronic Project BuildingReplies: 40Last Post: 09-12-2011, 03:33 PM -
Colchester Student 1800 Square Head Lathe - HELP !
By cncroger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 03-02-2008, 08:28 PM
