Page 1 of 5 123 ... LastLast
    Hi guys,
    Dave here. I'm designing a new machine for the office in the hopes of carving precision rifle stocks (4 axis) and whatever else is required from hardwood and aluminium. :)
    The build is already underway and frame currently ready to be painted.
    Details of the build
    Linear bearings: SBR20 fully supported rails - X:1300mm - Y:1000mm - Z:450mm
    Ball screws: RM2005 Chinese - X:1350mm - Y:1050mm - Z:500mm
    Steppers: Nema23 - 23HS45-4204S
    Drivers: M542H
    PSU: 48V 600w DC
    Frame/Chassis: 65x65x3mm box steel
    X axis chassis: 75x75x4mm box steel
    Gantry cross beam: 200x100x5mm box steel
    Gantry supports: 300x125x10mm steel angle
    Z axis supports: 200x480x10mm steel plate
    Contrary to most builds on here I do not have a CAD diagram to show as the build is a running design at present. I have very little CAD skills unlike my wife, who regularly makes designs in Solidworks.
    Here's some pics of the current build:
    original design
Name:	original frame.jpg
    Adjustible feet
    Front on view - all level within ~1mm
    Side view
Name:	frame with gantry.jpg
    Z axis setup.
    Gantry side on.
    Anyway, thought i'd share guys. let me know what you think. :)
    - Dave.
  2. The Following User Says Thank You to Slixxor For This Useful Post:
  3. #2
    Looking good so far Dave.
    Any reason for the 2005 ballscrews? The 1605/1610 are more popular because they have lower inertia which helps with the acceleration and deceleration, especially on the modest 48V you are using.
    I havent purchased the PSU yet. so may go larger. the motors claim to have a max voltage of 48v. i can get a 60V no troubles but am not sure of the impact that would have on the steppers. As far as the RM2005's goes, i was aiming for a rigid setup for cutting aluminium and didnt want any wobble from ball screws. Feed rate isnt that critical for me.
  5. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Slixxor View Post
    I wouldn't be worried about the steppers but the drives in your spec you have said that you are using these M542H If I am not mistaken the max voltage they will handle is 50V so 48V would be too high for them. AM882 drives would be a better choice running at about 68-70 V.
    If you want a decent machine you have to have decent electronics.
  6. #5
    Ok, it's now being considered. :) havent bought the drivers yet either. you are right indeed, my voltage restriction was the M542H. price is only AU $20 more per driver.
  7. #6
    Ok then if you have not bought the motors either then try and find 8 wire so they can be connected in parallel and get the lowest inductance motors you can find these are proved and tested by many over here :- http://cnc4you.co.uk/resources/Stepp...1B%203.1Nm.pdf.
    Good luck with the build.
  8. #7
    I have the motors already and all mounting hardware. saving the electronics for last. The AM882's are in the price range. I am running dual ballscrews on the X Axis. so additonal cost. but oh well :)
  9. #8
    You can run both X axis screws with one motor and belt connecting them,it's common practice with the guys on the forum.
    Good luck
    Mike
  10. #9
    Good luck
    Mike
    I have noticed that. but whats the go with custom belts? Obviously each machine will differ in length required. Do you simply ask for a particular length?
  11. #10
    You can get custom belts but they are more expensive, but you have a lot of leeway length wise as you will have adjustment on the motor and your tension/routing belt layout. there was a post on the forum a while ago showing a belt routing setup to address this issue.
    Regards
    Mike
  1. BUILD LOG: Desktop size steel welded router 3 axis
    By Tom J in forum DIY Router Build Logs
    Last Post: 28-03-2017, 09:36 PM
  2. Z-axis huge slack / beginning a conversion
    By diy-john in forum Gantry/Router Machines & Building
    Last Post: 04-03-2012, 10:26 PM
  3. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  4. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  5. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 12:47 PM
