Thread: PSU Assistance
    Hello, I've got a 42V 720W switched mode power supply running 4x AM882H stepper drivers with 4 x 60BYGH301B stepper motors (3.1nm/4.2A/0.65Ohm/parallel wired), running a 4x4 plasma table (dual motors to one axis) on a HTD belt drive acting as a rack & pinion arrangement.
    It's been running fine, but not happy about the switched mode power supply really, and it was only really a temporary fix, hence I was looking at using a torodial transformer, given these are AM88H drives, they accept accept AC or DC as they have their own rectifiers and capacitors internal.
    question, what voltage and VA rating would you go with...
    I was considering 2x50V / 1000VA, but the choices are really 2x45V, 2x50V, 2x55V, 1000VA, 1250VA 1500VA, 2000VA.
    from somewhere like here: / maplin do up to 1000VA.
    Yup, I've read all the gecko drive power supply selection info, and I know all about ac > dc x sqrt 2, etc etc.
    I am hoping to use the same drive box in different applications in my garage as I'm not intending to build another, hence for a lathe and milling machine if I ever get around to converting any of those.
    The BOB PSU is separate
    thanks for your time and any guidance.
    Lives in Marple Stockport, United Kingdom. Last Activity: 42 Minutes Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I think you could run that off 500Va and use 2x50V using 1000Va you will have problems with inrush etc
    Amazing, I would go in exactly the opposite direction and replace toroidal with switch mode
    Transformers make everything squiffy, heavy and complicated.
    Well from the drive info:-
    Regulated or Unregulated Power Supply
    Both regulated and unregulated power supplies can be used to supply the drive. However,
    unregulated power supplies are preferred due to their ability to withstand current surge. If regulated
    power supplies (such as most switching supplies.) are indeed used, it is important to have large
    current output rating to avoid problems like current clamp, for example using 4A supply for 3A
    motor-drive operation. On the other hand, if unregulated supply is used, one may use a power supply
    of lower current rating than that of motor (typically 50%
    70% of motor current). The reason is that
    the drive draws current from the power supply capacitor of the unregulated supply only during the
    ON duration of the PWM cycle, but not during the OFF duration. Therefore, the average current
    withdrawn from power supply is considerably less than motor current. For example, two 3A motors
    can be well supplied by one power supply of 4A rating.
    So take your choice
    So take your choice
    I always do
    I went off transformers for CNC when I tried to calculate the voltage to buy and what value for the smoothing cap.
    The am882h drives have built in bridge rectifiers and caps, but when I had the cover off (I was curious they were sold as refurbished) I should have written down the capacitance of the caps, hence the ripple can then be calculated.
    My switch mode is 720w at 42v and it can make a bit of noise when all three axis are running at the same time. Even though in theory it's rated at 14amps.
    Not so sure about 500va given its 250va per tapping (5amp) and the drives run at 4.2a hence if two axis are running off the same tapping at the same time they would draw worst case 8.2a, hence why I was edging toward 1000va (500 va per tapping or 10a rating at 50v)
    Thanks for the comments (any comments)
    Brad
    I'm currently a fan of transformers as they're easy to fish out of the university skip...but when the price is comparable a switch mode power supply is sensible. You can always add components if required to increase the peak rating.
    Quote Originally Posted by CNCStudent View Post
    Be careful not to mix up motor phase current with DC-bus current - they are rarely the same.
    With the switch mode you generate RFI I run 4 of those drives with 3.1nM Motors from a 500VA train with no issues like a lot of people on hear do.
    transformer rated at 50v ac, once rectified will provide ~70v DC (with no load), is this not a little high given the geckodrive guidance is 32 x SQRT (L), where L is in mH.... [32xSQRT(3.2) = 57v]
    there is also another bit of guidance that says, no more than 20 x the stepper DC rated voltage (4.2A x 0.65 Ohms = 2.73v; 2.7v x 20 = ~54v), or no more than 25x the dc rated voltage or the steppers would overheat at standstill.
    I am aware of ripple voltage will have onto the power supply when under current draw (hence interested to know what the caps are in the AM882H's)...
    other than cost... what would be the problem with a 1000VA transformer, inrush on a 13A fused plugtop on a 32A ringmain should not be an issue, and if it was, I could always use a solid state relay which would then allow for switching only a the crossover voltage.
    I got the 42V switch mode PSU, and although the nameplate says 720W (17A), it should really be able to deal with 4 stepper motors really, or at least just about (hence I was going to put one of the axis on another switchmode PSU), but it just seems to be like putting a plaster on the problem instead of getting the right power supply (a toroidal transformer) with a fair bit of design margin.
    Lets face it, I have a welder that is 200A rated for 6mm mild steel, but only ever tend to use it at ~110A on 2 and 3mm plate, is it really that detrimental having a bit of margin in components? [ok, it is inverter driven, digital controlled... semi-synergic...]
    Interesting in that I thought the guidance would come on voltage choice and not a VA rating discussion... as I could not make my mind up if 50V or 55V would be right for the steppers and drives or whether I was over rating it and should have been looking at 45v transformer output rating, given the no load DC voltage would be about 63V.
    hmmmm... well I've just read one of the other posts on building (more correctly assembling) PSU's / components and was intrigued by the use of an NTC thermistor for inrush current protection.... (time to do some reading and learning)..... [never took it to be much of an issue really .... we just normally just change the type of breaker (D type) to alter the characteristic curve to stop nuisance trips....]
  1. NEW MEMBER: Tunisien request for assistance
    By ali hedi in forum New Member Introductions
    Last Post: 01-06-2009, 05:37 PM
