    Hi guys,
    I need to hire a wood-working shop for a day or two. I've found one in Battersea which looks good but is quite a long way from me in Gravesend, Kent. Can anyone suggest an alternative?
    The job I need to do is pretty simple; just rip some sheets of ply, add a plain rebate to each side then cross cut them. So I need a table saw and a router table / spindle moulder.
    Any ideas, or do you have a workshop that is not fully utilised?
    Regards,
    Simon
    Men's Sheds are a great Aussie idea....... partly to make up for being so submissive at cricket ;)
    Looks as if there are now Men's Sheds already open in Dartford and Gillingham.
    1. just rip some sheets of ply.
    2. add a plain rebate to each side.
    3. then cross cut them.
    cant you use a circ saw ? run against a straight edge.
    you could use a router to add the rebate.
    depends how wide the pieces are... you could cross cut them with a chop saw.
    or a radial arm saw.
    Thanks. It's not the tools that are the issue it's the space to work and make some mess. I used to have a table saw but sold it when I moved due to the space.
    fair play, i do what i can in my garage, and what i cant outside it. ( weather permitting )
    Bugger, I forgot to give you the weblink which is http://menssheds.org.uk/find-a-shed/
    Looks like the Gravesend Shed is yet to come, but there are already Men's Sheds already open in Dartford and Gillingham.
  1. Recommendation for getting MDF worked on in North London?
    By surv1v0r in forum General Discussion
    Last Post: 10-09-2014, 12:09 AM
  2. Spindle Motor Recommendation.
    By cambesol in forum Marketplace Discussion
    Last Post: 21-11-2013, 12:15 PM
  3. Router recommendation for University
    By S2L in forum Marketplace Discussion
    Last Post: 05-12-2012, 11:58 AM
  4. Router bit recommendation, spindle speed and feed rate?
    By FlightCaseCo in forum Spindles & Drive Motors
    Last Post: 03-04-2012, 12:53 PM
  5. NEW MEMBER: Have woodwork, looking for a router owner who may be interested
    By Lance in forum New Member Introductions
    Last Post: 08-06-2011, 01:28 PM
