  1. Hi,
    Does anyone here have a 'Haimer 3D-Tester New Generation' dial? I find I have to realign the concentricity of my dial every single time I use it - Not a single day passes by without the damn thing needing readjustment. Am I the only one who has this problem? Also, does anyone else find it takes a lot of force from the grub screws to get the probe concentric?
    The whole point of buying the dial was to save time aligning things on my machine - I was not expecting that I'd have to frig about for 20 minutes every time I want to use the stupid thing. After using the dial yesterday, I accidentally broke the probe tip and almost threw the dial across the room! Wish I hadn't spent the money on it - a five quid wiggler seems to do a better job.
    Matt.
  2. Well, I guess the complete silence is testament to the value others see in the Haimer - In the junk drawer it goes.
    Matt - there might be a lot of people out there, like me, who've never heard of these things before. I've just had a look at the website, and I can see that they might be useful to someone doing second-operation jobs who need to accurately reset workpieces. I suspect that a lot of CNC users don't work this way; one setup per workpiece where profile and internal machining is done at one setting is more common? I'm thinking out loud here, but that's the way I usually work. Vertical mill (mine is still manual - CNC conversion is on the list...) is a different matter. However, I find a conventional wiggler very quick and easy to use. Haimer seem to suggest that calculating half ball diameter is a complex, difficult, job. Maybe US education is a little different from European education, but I don't find calculating half of 0.2500 to be so very difficult. I don't even need to use my fingers to count or anything. And with a DRO, pick up the edge, switch to imperial, punch in 0.125 (+ or - as appropriate), and if necessary switch back to metric. And using a wiggler with a DRO to find centres is trivial.
    Haimer seem to be talking of commercial systems where you can permanently put the edge-finder into a toolholder, and I would guess that this takes out recalibration every time you pick it up. Me, I'm swapping collets all the time and I would expect to recalibrate because I'm not sure that ER collets are that good. The wiggler is beautifully self-calibrating. But I don't have customers paying for my time so the time/money calculations are somewhat different.
    I did look at one of these a while ago and ended up buying the Tschorn one. Excellent little toy it is too.
  5. Thanks for the replies - Most the things I do on my machine require second operations. I bought the Haimer in the hope it would help realign workpieces more accurately than a wiggler - Just seems to cause more trouble than it's worth though. I don't have any problems with my ER collets - No concentricity issues with my end mills.
    Are you sure, you have no spindle or toolholder problem. Maybe a little chip that is clamped between spindle and toolholder.
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Hour Ago Has been a member for 9-10 years. Has a total post count of 1,602. Received thanks 110 times, giving thanks to others 69 times.
    Sorry, old thread, looking for probes, my electrical el cheapo seems unreliable. I was looking at Haimer but found the Tschorn ones, it sounds like YMTTooling stopped selling Haimer (perhaps due to issues) and now sell these - http://www.ymttooling.co.uk/122-prob...ng-instruments. Will probably go for the VIP Plus one.
    Any feedback or similar before I buy?
    Once again I'm gonna link to Cliff from "Down Under" his probes are coming along nicely now, and should be available soon.
  1. Calibration issues, advice needed
    By Kernow Jim in forum Motor Drivers & Controllers
    Last Post: 23-01-2014, 07:18 PM
  2. calibration
    By luke11cnc in forum Computer Software
    Last Post: 11-02-2012, 01:03 PM
  3. NEW MEMBER: MDF Problems
    By MrWiz73 in forum New Member Introductions
    Last Post: 31-12-2011, 12:39 AM
  4. Problem with calibration
    By m.marino in forum Gantry/Router Machines & Building
    Last Post: 22-04-2010, 04:19 PM
  5. Chronoscope Calibration Tool
    By Robin Hewitt in forum General Electronics
    Last Post: 29-11-2008, 01:26 AM
