  1. Hi all, been off the air for a long while for various reasons, but hope to resume 'normal' service soon (or as normal as it gets these days).
    Anyway, I need to find a U-shaped bit of steel (channel) around 35mm high x 35mm long with the channel width internally about 6.5 +.5/-0 formed from 0.8 - 1mm sheet. Needs to be magnetic, so has to be steel, and finished in a brushed/satin effect.
    Ideas anyone?
    Welcome back Irving it's been too long so nice to hear from you again.
    Can't you just form this around a piece of material the width of your channel. 1mm sheet bends easy enough so shouldn't be a problem.
  3. Hi Dean,
    Yes, its been too long, tbh got a little too inwardly focussed and last 6 mo or so I've struggled with just coping day to day, but trying to get up n running again.
    Well if I had some tools and some hands to use them I probably could... but my tools are still in storage and I couldn't use them anyway. Anyway, I think the way to do this would be to cut them out with a plasma or laser cutter to get neat radiussed corners (failing that, tinsnips and a file ), do the surface preparation (not sure what exactly, want a brushed, stainless finish) then score the back and fold using some 6mm mdf say as a former.
    Good that you are back online.
    Just my usual two pennuth - dont forget - most stainless steel is low magnetism.
    Cheeers,
    Rob
  5. Thanks. Wasn't suggesting making them from stainless, just needs a brushed steel/stainless effect finish that wont rust! Not sure how you get that.
    Use a magnetic grade of stainless, they're not as corrosion resistant as non-magnetic grades but still stay bright in most non-marine applications,
    - Nick
    How many do you need ?
ID:	16577Click image for larger version.
    Hi Irving,
    I have just cut and bent this. it is 7mm inside (but springs inwards to 5mm at open end) 40mm x 34mm at the moment. I need to deburr and finish. If it is too long let me know. Otherwise I need a quantity on this order and a despatch address as a PM.
    There is the option of a black neoprene (?) foam 1mm thick if you want it lined with it. I can also offer cork and neoprene gasket if that would be better.
    Cheers,
    Rob
  9. Rob,That's brilliant, thank you. I need two identical ones. It has to fit over 6mm glass so 7mm with something internal like a thin neoprene sheet would be fine, as long as it stays put. 1mm neoprene might be a little thick though. Being pedantic, the only thing I'm not sure about is how tight that will sit against the edge of the glass, the commercially available, but too small, ones look squarer in profile
    Is it magnetic? Or will I n<script id="gpt-impl-0.25115873216392326" src="http://partner.googleadservices.com/gpt/pubads_impl_75.js"></script>eed to glue some thin steel sheet to the back?
    PM on its way.
  1. looking to have a cnc made for me
    By Ben-bee in forum Marketplace Discussion
    Last Post: 11-10-2015, 07:40 PM
  2. Made to measure furniture
    By irving2008 in forum Projects, Jobs & Requests
    Last Post: 19-11-2014, 05:33 AM
  3. How are these made...
    By jashington in forum General Discussion
    Last Post: 31-10-2013, 08:07 PM
  4. EXPERIENCE: Z Plate made by DOM
    By dudz in forum Trading Experience & Feedback
    Last Post: 28-11-2012, 08:12 PM
  5. Home made CNC for 50 €
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 26-05-2009, 08:12 PM
