05-03-2016 #10
if i can suggest popping over to here...
http://www.mig-welding.co.uk
You can pick up a lot of good help, *some* of those welds look ok, some look dodgy but all will most likely do the job.
You should not need to re-run a weld, what sort of gap are you bridging? Any more that a mm or so and you will struggle.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
