Thread: TD torch cut height enquiry
I have a little Thermal Dynamics Cutmaster 38 with a 30amp drag tip. I use a floating head without THC set to zero of each cut.
I'm trying to find out the correct distance to pierce and cut with using this TD machine. What i'm reading suggests I should be cutting at about 3mm above material but since the plasma has a 30amp drag tip it works best on thin steel at 0. However 0 is not realistic. I'm just thinking about the consumables and cut quality and whether there is a standard height I should be looking at.
In Sheetcam I have the settings for 3mm mild plate set to:
kerf 1mm
Feedrate 1500mm/min
pierce delay 0
pierce height 9mm
plunge rate 300mm/min
cut height 2mm
Torch Height control
By Bobp in forum General ElectronicsReplies: 21Last Post: 09-12-2019, 04:46 PM -
Z Height - Max?
By Chaz in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 04-02-2016, 11:18 AM -
FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
By nobby in forum Items For SaleReplies: 0Last Post: 20-05-2014, 07:33 PM -
Plasma, Mach3, Sheetcam and a Proma Torch height controller..
By Davek0974 in forum Plasma Table MachinesReplies: 2Last Post: 14-04-2014, 03:49 PM -
RFQ: Early enquiry
By boldford in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-07-2012, 06:40 PM
