Thread: Thor, or should that be Zeus?
19-12-2016 #141
Wow, 3 months have gone, I am piss poor at keeping this thread updated.
So gantry was done, Y motor mounted, some test movement here:-
https://www.youtube.com/watch?v=5sMb4XmzuXc
Ignore the last 100mm or so that is unsupported. Long story, That will be epoxied it later.
A pic of how it all looks, my wife not happy with me taking pics of her. Testing the fit before I attempt to epoxy this lot together.
19-12-2016 #142
19-12-2016 #143
27-12-2016 #144
...seems to be a lot of water.
In my work place we add circa 30 litres of water to 750kg of mix (all depends how wet is the sand).
This gives nice mix to form roof tiles. 10% water too much and mix is too wet and have to be dump - happens daily.
My point is to get correct amount of water - mix it well and we shall get strong cement.
27-12-2016 #145
27-12-2016 #146
Should add that the mix goes through bed/slipper which is kind of mold and is compacted by packshaft with fingers - layer of concrete is 12mm thick and travel 1m/s speed.
In your case vibrating plate is a must. Curing process is complex too (4 stages with extra water), retarder is used to slow curing process.
Since I work there, I use min amount of water (just for mix to be not brittle) - for diy concrete job
The Following User Says Thank You to Tom J For This Useful Post:
Tom I am not sure you are understanding this way of moulding concrete as it is done with superplasticiser which makes a very fluid mix and MUST NOT be vibrated as it will settle the aggregate to the bottom. The way it works is that it separates all the individual fines and stones in suspension for about half an hour then they come back together for the set.
This explains it better. https://www.youtube.com/watch?v=9ySyaKb2_b0 and here https://www.youtube.com/watch?v=ICp4...w#t=107.971789Last edited by Clive S; 27-12-2016 at 02:40 PM. Reason: added extra link
27-12-2016 #148
27-12-2016 #149
