03-03-2016 #1
* A QUOTE FOR THIS HAS NOW BEEN ACCEPTED *
RFQ: Aluminium plate, basic dimensions 150mm x 140mm x 12mm
16 holes machined to accomodate M5 cap bolts - not threaded, with cap sunk under surface of material.
19 additional holes drilled/machined and tapped to take a M6 bolt
You to supply material, machine, and deliver to Lancashire, UK.
(Background, this is a first attempt to mount a replacement spindle onto the Z-column on a StarMill machine... I would attempt this, except the size is rather too large to work on the StarMill as a single operation)
MikeLast edited by Doddy; 06-03-2016 at 10:03 PM. Reason: Addition of dxf
where to get aluminium plates cut and drilled
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 30-08-2015, 12:28 PM -
RFQ: RFQ: Gantry in Aluminium plate
By IanS1 in forum Projects, Jobs & RequestsReplies: 1Last Post: 03-10-2014, 03:51 PM -
WANTED: 100mmx100mm 6mm aluminium plate/sheet.
By Isaac in forum Items WantedReplies: 11Last Post: 06-02-2014, 12:11 AM -
RFQ: Rounded slot milled through 15mm Aluminium plate
By TonyD in forum Projects, Jobs & RequestsReplies: 2Last Post: 15-02-2013, 11:20 AM -
what is aluminium plate
By martin54 in forum General DiscussionReplies: 10Last Post: 11-10-2012, 01:44 AM
