    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Days Ago Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    Free to whomever can use it as long as you pay for postage (or collect from me in Ickenham). I assume it works, but never used it. Came off my Denford VMC.
    I also have the chassis and most of the cards for the PC, same deal except in this case I believe the PC didnt boot. Free ...
    Hi Chaz,
    Do you still have the denford bits?
    Chaz's Avatar
    Quote Originally Posted by drumsticksplinter View Post
    Hi Chaz,
    Yes. The PC chassis has been stripped down however, so I have all the component parts and will need to be rebuilt. I dont know what works / doesnt work but you are free to have it. Collection preferred - UB108TE.
    I'm in a bit of a predicament at the minute... I've had a load of trouble with my denford cyclone, it seems that the 20 year old electronics are no cooperating, so I'm debating whether to persevere and keep patching up the problems, or write it off and install something like cslabs csmio/ip-a running with mach4?? decisions.... can you offer any advice to help sway my decision?
    Chaz's Avatar
    Replace, no discussion! Been there ..... I had tried to use my drives / motors etc. Remove the variance when things dont work and the older stuff is not as good or reliable.
    It costs more but you will have a better / more modern machine.
    I may be able to provide some other kit too if interested (motors etc), let me know if interested.
    Thanks Chaz,
    Hmm, so I've spent a bit of this morning pulling out the old boards and drives. Looks like I'm going for a retrofit. What system did you go for? I'm thinking cslabs, they seem a bit more expensive, but also more robust?
    Chaz's Avatar
    Thanks Chaz,
    Yep, CS Labs. There is a full thread on my retrofit on this forum ... dont have the link at hand now but its around. Look for Triac VMC.
    Here it is: CONVERSION: Denford Triac VMC with ATC
    .Me
    .Me
    Hi, Do you have “baldor D281 motion control card for a triac P. C. (denford), red 7-segment LED display type. The firmware is ESMINT 3.28 V1.6H/S - JD5.”
    Chaz's Avatar
    Quote Originally Posted by Tommy View Post
    Did you see my post on another thread on the cards that I had found?
  1. keyboard interface problem (Denford lathe)
    By asto in forum Denford Lathes
    Last Post: 29-07-2015, 06:38 PM
  2. RFQ: Prototype keyboard case - CNC and laser
    By Photekq in forum Projects, Jobs & Requests
    Last Post: 26-05-2013, 08:18 PM
  3. Mach3 custom USB Keyboard
    By rnr107 in forum Electronic Project Building
    Last Post: 21-06-2012, 02:53 PM
  4. Cheap Monitor and Keyboard arm at CPC
    By Musht in forum Monitors
    Last Post: 12-05-2012, 12:58 AM
  5. This tiny keyboard might come in handy :)
    By Smiler in forum Gantry/Router Machines & Building
    Last Post: 28-12-2009, 06:30 PM
