hi. I am having a few faults with my mill and wonder if someone out there can help. I am using the following software. to draw the part I am using solidworks and then importing to fusion 360 to make the g code. I check the drawing worksheet in fusion to make sure that the part is correct.
then I download the g code to mach 3. but when I start milling on my little proxxon mf70 the part is 4 x larger. what am I doing wrong.
michael
09-03-2016 #2
09-03-2016 #3
Does your machine move the correct distance when told to.? . . . You could have the Steps Per setting wrong.!
Only other thing can think of is if you have entered a Scaling factor into Mach but you'd know this because the Scale would Falsh Yellow.
Other than that without seeing the Cad model and G-code file can't really help.
10-03-2016 #4
As i am not an expert i am not the best one to advice people, BUT check if you have any issues from mm to inches as 4 X 1 inch(2,54 cm)=10,16 cm. So may be a compbination of what Dean said ( scale factor X 10 ) and cm instead of inches or any program factor that converts inches to decimeters.
Just an idea
VagelisLast edited by ba99297; 10-03-2016 at 12:32 PM.
The creative adult, is the child who survived
Fusion 360 - best approach?
By routercnc in forum Fusion 360Replies: 10Last Post: 18-06-2016, 07:49 AM -
When it all goes wrong
By alboy in forum General DiscussionReplies: 2Last Post: 12-12-2015, 01:16 AM -
What has gone wrong????
By Davek0974 in forum Plasma Table MachinesReplies: 54Last Post: 05-09-2014, 12:25 AM -
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
larger home made milling spindles - NMTB/ R8 taper?
By jonnydeen in forum Tool & Tooling TechnologyReplies: 6Last Post: 13-09-2012, 11:17 AM
