Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
  1. #151
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    IIRC the timer gets reset every time you press cycle start.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #152
    Well done looking good now
    I'm sure you know the clamps are better if the bolt is at the work piece end rather than middle - slotted clamps and more bed plate holes would be a good next step when you get a moment. Good stuff anyway . . .
  4. #153
    Yes, thats standard clamping law - bolts close to part and back end of clamp slightly higher than part;)
    They do work well though, todays part was another total success, I don't think the stress on the part is that high in this case, there is only one cut that will put it under strain - the second/last pass on the 5mm roughing tool which separates the parts from the central stub, after that it's just light tickling with the 2mm tool.
    The next major issue is getting some sort of chip control round her - the mess is ridiculous.
  5. #154
    More questions, anyone care to put pics up of their whole setup?
    I'm looking to find a home for the damn keyboard, monitor and mouse - this lot seems to take up more space than the machine! The keyboard and monitor are also suffering under the shower of chips ;)
  6. #155
  7. #156
    Nice, way too clean and tidy ;)
    Wall mounted monitor is good, the keyboard and mouse is sort of where mine is but the chips get flung for about a 4 foot radius when cutting so i have to cover the KB up every time i press start!
    I need to move it to a better location really but space is tight, or poorly arranged, or both ;)
    Too much in one room really, it's 5.2m x 4.2m - CNC plasma, CNC milling, manual milling, pillar drill, lathe, power-coating station and oven, bench, pedestal grinder/buffing, Mig welder and bench, 20T press, bandsaw, metal storage, probably more....
  8. #157
    Mine is not set up yet but Monitor on wall and keyboard mouse just below on swinging shelf or a 14" CRT tv bracket in a former life with a piece of MDF attached swings all ways including back to wall up out of way of chips. I also have the Mill sitting in a 700x700x7mm plastic garland tray from amazon catches lots of chips and fluis if necessary come in all different sizes extremely useful in workshop.
    http://www.amazon.co.uk/Garland-2251...ilpage_o05_s00
  9. #158
    As a move in the right direction, i have fitted some bracketry and mounted the monitor up high out of the chip path, the brackets stem from the main table frame which is 44x44 structural aluminium, makes it easy to bolt bits on ;)
    I also did a facing cut on the bed, here's a video of a bit of it...
    https://youtu.be/PSkSn_s8xF8
    It was with a 12mm indexable carbide tool at 21000 rpm and 2300mm/min feed, DOC was 0.15mm, just enough to get a cut off the whole face.
    The results show the head is a tiny bit off-tram but until i get a decent setup for adjusting it I think it best left where it is, using a DTI it seems the slight ripples made by the tool are about 0.01mm high at the peak,not bad i think as the head was just as i bolted it on!
    All things being equal, the results from now on should be 'as good as it gets' for a while at least.
  10. #159
    Still running good, much better in fact after doing the facing cut on the bed - i think this should be the first job on any machine as it makes such a difference.
    Now have Vectric software which seems pretty good. Does anyone here use it know if there is a way to enter g-code snippets into the job process list??
    Things like selecting G5x Offset or adding a pause, message etc ??
  11. #160
    Don't know about inserting g-code using Vectric directly, but you can read the .txt gcode files it creates using a text editor such as 'notepad' and add the lines manually. Or you can load the code into Mach3, then there is a code editing button which opens a text editor which you can then edit.
  1. Beginner Moving Gantry Build? Read This!
    By Tenson in forum Gantry/Router Machines & Building
    Last Post: 23-05-2018, 05:30 PM
  2. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  3. Truss style Gantry
    Last Post: 15-12-2012, 07:23 PM
  4. A few questions to start a DIY mini CNC
    By purple_rob in forum Gantry/Router Machines & Building
    Last Post: 03-08-2009, 11:08 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
