Thread: Aluminium Framed Router
30-04-2016 #14
Drilling into the end, cutting both shaft and pulley, is an established technique but you will find it difficult to do accurately with an aluminium pulley as the drill will start to wander. Also, it's a mistake to drill for grub screws at opposite sides. You are now balancing the force of one grub screw against the other. Much better to drill at 90-120 deg apart, so both grub screws and the bore of the pulley grab the shaft. That might give some useful extra grip. You could just file a small flat on the shaft for one grub screw to bear against?
Good luck - I haven't reached this point on my own machine yet!
Large Format Steel Framed Router
By nathandavies in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 07-02-2016, 02:51 PM -
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Steel Framed Router
By GTJim in forum DIY Router Build LogsReplies: 52Last Post: 14-09-2011, 06:51 PM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
