    Make sure you don't have the lead plugged into the current connectors marked "A" or "mA" - For voltage they should be plugged into "COM" and "V". Its very easy to forget.
    Graeme
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Graeme View Post
    Graeme
    Yes but good meters don't let you do that. But good point. Dave: By capacitance I meant from the leads they act as a capacitor if they are very close.
    Thanks guys,
    Definitely on the volts, this meter only has three sockets - V/mA, Com, 10A and i only used the Com and V/mA ones 99% of the time.
    I can't see lead capacitance having any effect here, surely it should be a measurable 0 to 10v Dc signal going to the VFD?
    I know 4-20mA can be a pain to measure sometimes unless its loaded properly but 0-10v?
    I fired the question at cnc4you and just got a reply - yes i should be able to measure 0-10v there, so i have no idea why i cannot.
    Sounds like you have dodgy Bob to me.? 100% should be able to measure the Voltage coming out the speed Controller.
  5. #15
    Bugger, sounds about right for my luck.
    But then how the heck does it manage to work at all?
    Might be worth putting the 'scope on it?
  6. #16
    A telescope won't help
  7. #17
    I think he meant a proctoscope
  8. #18
    I think you meant a endoscope
  9. #19
    No I meant a proctoscope ! Happy Easter Clive..
    Serious suggestion now - If you have an analogue meter these can have impedances as low as 5000 ohms per volt. All electrical measuring devices draw current from the circuit and this affects the circuit (experts can get precious here, but I am simplifying !). Having said that, I would not expect the BoB to be such a high impedance source as to have a drastic voltage drop when meter is put on it.
    As Jazz says, it could be a dodgy Bob. I have never met a Dodgy Bob, but I do know a bloke called Dodgy Dave.
  10. #20
    Yep happy Easter Rob I was just jesting Avo 7 days and valve volt meters.
  1. Stepper motor Pulse Signal Generator module
    By Tom J in forum Motor Drivers & Controllers
    Last Post: 12-01-2016, 11:47 AM
  2. AM882 Alarm and Enable Signal Question
    By Gotty101 in forum Motor Drivers & Controllers
    Last Post: 24-11-2015, 11:07 PM
  3. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  4. Encoder Signal to PC
    By antsals in forum General Electronics
    Last Post: 26-04-2011, 10:49 AM
  5. +5V TTL Signal
    By NC-Joey in forum General Electronics
    Last Post: 12-08-2007, 02:46 PM
