Where to buy from 1/2" shank or ER25 led sound probe? With ball at the point,steel ball and body, and that does not cost arm and leg?
i see a lot of cheap ones but 20mm shank. Any idea some one? i searched a lot but could not find something under 100. At the same time the 20mm ones are darn cheap
22-04-2016 #2
Smallest I have seen was a 16mm on aliexpress, doesn't er25 go to a 15/16mm collet seen a few sets that included 16mm. I think ER20 1-13 and ER25 1-16mm
http://www.aliexpress.com/item/Free-...6-2c7884a1942bLast edited by lucan07; 22-04-2016 at 10:24 PM.
22-04-2016 #3
The Following User Says Thank You to magicniner For This Useful Post:
22-04-2016 #4
Close but no cigar -
http://www.teng.co.uk/4200-125-metri...ge-finder.html
23-04-2016 #5
I have 2 of the 20mm shank ones. Not worth the effort... they are hardly any better than a trusty edgefinder. My issue with them is that they are so long that they run out all the time. The only way they make sense is if you have ISO40 ISO50 size taper tooling and you get then set up correctly.
The only other one I have seen was an american made one with an LED inside it. 10-12mm shank exactly like the link to Teng aboveLast edited by komatias; 23-04-2016 at 12:07 AM.
https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
23-04-2016 #6
yes, sorry, ER20 collet. so 1/2 max
That one is ok but no ball. If mistakenly turn hanle to the other side could be damaged. But seems no other choice for now. Anyway, it's for my small mill, which i use for drilling. So i need it to find faster the edges
I have seen that one, the american, with the ball, but is expensive.
I was wondering the same thing though, if a Starrett edge finder would be better and more reliable. But as i said, on the CNC i have the MachStdMill screen set which is much better than any edge finder
Any ideas or thoughts on making a edge finder come touch off tool
By suesi34e in forum Electronic Project BuildingReplies: 26Last Post: 01-01-2020, 06:28 AM -
"Hacking" and "Modding"
1/4" / 6mm edge finder?
By jcb121 in forum Marketplace DiscussionReplies: 0Last Post: 18-03-2013, 02:58 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
Electronic edge finder: how do they work?
By irving2008 in forum Probing, Digitizing & ScaningReplies: 14Last Post: 29-08-2009, 10:25 PM
