28-04-2016 #1
(As per the title, the bloke doing the work is Chinese, so I need to keep the instructions simple ...
I need some sfu1204 machined & need the resulting ends to be a tight fit when inserted into a bearing with an 8mm ID / bore.
But what would a tight fit be? 7.99mm? (because obviously 8mm machined ends will not fit into a bearing with an 8mm ID)
Bloke in Bristol needs help
By keith wainwright in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 02-02-2016, 12:10 AM -
top mounted ballscrew, would it work properly ?
By Rory13 in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 10-06-2015, 07:21 PM -
Techsoft 2D Design to work with Chinese CNC 3040 DJ-T
By lukelucas93 in forum Machine DiscussionReplies: 3Last Post: 11-09-2014, 03:06 PM -
My first bits of work from a chinese 3020 cnc
By Jester in forum Woodworking Project ShowcaseReplies: 11Last Post: 02-02-2014, 12:08 PM -
NEW MEMBER: Bloke in uncoverted loft with 3 dot matrix printers says hi
By HankMcSpank in forum New Member IntroductionsReplies: 18Last Post: 07-06-2009, 11:01 PM
