    Can someone please advice me on what what size drag chain and what lengths to get for a bare bones 6040CNC. I am going to use a water cooled spindle, run a compressed air line and use shielded CY cables for stepper motors, limit switches and home switches. There will be 6 limit switches and 3 home switches with separate cables for each.
    Tend to come in 1mtr lengths and I used 15x30mm to hold everything water, power, and control on similar size build 2mtr being plenty.
  3. The Following User Says Thank You to lucan07 For This Useful Post:
    Cheers. The help is much appreciated.
  5. #4
    Lives in Plymouth, United Kingdom. Last Activity: 15 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    If you order this drag chain, it seems to be priced by the metre (reasonably enough). If you order, say, 2 or 3 metres do you get a single length with just one set of end adaptors or 2 or 3 1-metre lengths each with end pieces? I'm about to order some and was wondering about this - or even if it much matters.
  6. #5
    You could even 3D print it in purple PLA
  7. #6
    Well, thank you, Rob, for that suggestion! And don't think that I haven't considered it. Purple goes so well with my complexion...
    I've also made a couple of short lengths CNC-routed from MDF based on a design I found on t'internet. That worked, but there are times when even I reckon that just buying something is easier than making. The digital panel meter I need to replace the meter on my variable voltage PSU is costing me 79p, post free, from China. I couldn't even buy the display for that price. And drag chains just have so many pieces to build up a decent length...
  8. #7
    I got my 2 x 1mtr of 15x30 with ends from amazon(warehouse) sells off returns and damaged packs, just keeping a watch for same, cost me £2.50 mtr rather than normal £10 they seem to come up regularly. Printing for a few wires is simple for printers lasers but with the amount and type of cables involved strength will be an issue with 3d printing unless you make it very bulky.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Relationship between Guide rail length and ballscrew length
    By CharlieRam in forum Rails, Guideways & Bearings
    Last Post: 11-07-2014, 11:37 PM
  3. Cable drag chain
    By birchy in forum General Electronics
    Last Post: 04-01-2014, 12:45 AM
  4. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  5. Stepper shaft size and pulley bore size problem
