02-05-2016 #1
Hi all,
A local guitar tech I've done bits and pieces for in the past got in touch recently to see if I could make him a punch/die for knocking out small plastic parts (in ABS). I turned down the project (I know nothing about punches/dies and expected the tolerances to be very high to get anything that would stand a chance of working) and recommended that he post an RFQ up here, which he did. I got in touch with him after a few weeks to see how the tool came out - turns out that getting it made was going to be too expensive to justify for the relatively little use it would get. Being a hobbyist with nothing to lose but a weekend, I thought I'd have a go at it, here are the results:
I thought that a bar clamp would be enough to work the punch and it was for one of the plastics I tested it on, but I had to use a larger medium sized G-clamp to find enough force to punch through the ABS. Quite happy with how this came out - it is a bit of a faff to use and it's a bit sloppier than something you'd get made professionally, but hey - it's made and it'll hopefully get a bit of use. If I made another then I'd probably look into running a ball-nose inside the profile of the punch and 'hollowing' it out a bit so as to concentrate the cutting force along the edge of the punch as opposed to across its flat surface - makes sense and would almost certainly make the punching through a lot easier, but could have a detrimental effect on the finish. Any hints and tips..?
Wal.
(EDIT: Plates were cut from 4mm 7075(T6) and the punch was cut from what I believe to be 2014)Last edited by Wal; 02-05-2016 at 06:07 PM.
RFQ: Someone to make a small punch die
By Steve Robinson in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-03-2016, 09:40 PM -
hole punch for tobacco tin ideas please :) ?
By Fivetide in forum Metal Finishing TechniquesReplies: 22Last Post: 01-07-2013, 09:28 PM -
Milling vice, general milling vice or tool vice?
By Web Goblin in forum Tool & Tooling TechnologyReplies: 4Last Post: 15-12-2012, 11:15 PM -
What vice for a Sieg X2?
By TheChunk in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 21-10-2010, 09:06 PM
