    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 31-03-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hi all,
    A local guitar tech I've done bits and pieces for in the past got in touch recently to see if I could make him a punch/die for knocking out small plastic parts (in ABS). I turned down the project (I know nothing about punches/dies and expected the tolerances to be very high to get anything that would stand a chance of working) and recommended that he post an RFQ up here, which he did. I got in touch with him after a few weeks to see how the tool came out - turns out that getting it made was going to be too expensive to justify for the relatively little use it would get. Being a hobbyist with nothing to lose but a weekend, I thought I'd have a go at it, here are the results:
ID:	18368Click image for larger version.
ID:	18362Click image for larger version.
ID:	18366Click image for larger version.
ID:	18372Click image for larger version.
ID:	18365Click image for larger version.
ID:	18363Click image for larger version.
ID:	18364Click image for larger version.
ID:	18371Click image for larger version.
    I thought that a bar clamp would be enough to work the punch and it was for one of the plastics I tested it on, but I had to use a larger medium sized G-clamp to find enough force to punch through the ABS. Quite happy with how this came out - it is a bit of a faff to use and it's a bit sloppier than something you'd get made professionally, but hey - it's made and it'll hopefully get a bit of use. If I made another then I'd probably look into running a ball-nose inside the profile of the punch and 'hollowing' it out a bit so as to concentrate the cutting force along the edge of the punch as opposed to across its flat surface - makes sense and would almost certainly make the punching through a lot easier, but could have a detrimental effect on the finish. Any hints and tips..?
    Wal.
    (EDIT: Plates were cut from 4mm 7075(T6) and the punch was cut from what I believe to be 2014)
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    As usual Wal you always come up with an interesting project very nice.
    Wal's Avatar
    Cheers Clive,
    It's worth having a go, isn't it?! I reckon I'll be sitting down to re-design all of my axis based around profile-rail soon enough, could do with a bit of extra rigidity - will look at enlarging the x-axis travel too. Hopefully catch up with you soon!
    Wal.
    Very nice, thanks for sharing :)
    Awesome Wal - I know where to come to get a new truss rod cover for my Les Paul now :)
    BTW - where do you get your 7075 from?
    Wal's Avatar
    Thanks guys.
    I've used metalweb a few times now - they have a depot not far from me. It's not cheap - IIRC I paid about £80 for 5 sheets of 200x500x4mm. Lovely stuff, though. Machines pretty well and has a Brinell Hardness rating of 150 (compared to 90-odd for 6082T6). Nice work on those guitar bodies, BTW - looking really good.
    Wal.
  7. The Following User Says Thank You to Wal For This Useful Post:
  8. #7
    Nice Job!
  9. #8
    Nice Wal, always top notch the bits you do!
    Neil...
    Build log...here
  10. #9
    Wal's Avatar
    Cheers Neil..!
  1. RFQ: Someone to make a small punch die
    By Steve Robinson in forum Projects, Jobs & Requests
    Last Post: 08-03-2016, 09:40 PM
  2. hole punch for tobacco tin ideas please :) ?
    By Fivetide in forum Metal Finishing Techniques
    Last Post: 01-07-2013, 09:28 PM
  3. Milling vice, general milling vice or tool vice?
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 15-12-2012, 11:15 PM
  4. What vice for a Sieg X2?
    By TheChunk in forum Milling Machines, Builds & Conversions
    Last Post: 21-10-2010, 09:06 PM
