Page 1 of 7 123 ... LastLast
    just received the above machine today, does anyone know much about them?
    it has a porters cable 23k spindle where is the best place to buy additional collets?
    also is that a vacuum pump under the machine? what sort of vacuum table would I need to do work stuff on?
  3. The Following User Says Thank You to andy_con For This Useful Post:
    Well done, bring on the retrofit !
    .Me
    .Me
  5. #4
    ok im struggling its not going as well as id like
    ive got a tiny amount of movement on the Y but cant get others moving
    ive done in
    but unsure if I need to do this
  6. #5
    anyone got any thoughts on how to connect up this BoB -
    https://www.cnc4you.co.uk/Breakout-B...xis-with-Relay
    to a spindle v4 board
    http://www.diycnc.co.uk/forms/spindleV4.pdf
  7. #6
    lots of help, offered.
    thanks
  8. #7
    At first look it appears incompatible to me as your bob is lacking outputs pin 14 on port is usually linefeed or control 1 as used on board shown in spindle board diagram this is not available on your BOB I would contact DIYCNC on the email on instructions tho they may just say buy another bob or possible take feed directly from parallel port.
    Knowing nothing about these particular boards I could not advise on non standard wiring.
    Just noticed your using a smoothstepper so may be able to pick up 14 16 17 and Gnd from that again not familiar but from memory what I have read may be possible.
    A quick google sugests this is possible but be aware that they use the old wiring on the board according to what I read 1-13 on one side and 14-26 on other standard now is odd one side even the other.
  9. #8
    Looking at the datasheets, the BOB and V4 are not compatible.
    Without swapping either component or buying a new BOB, I'd say wire the V4 straight to the second port on the SS.
    You could buy a second BOB which uses common ground for the step/dir pins, but if you're only going to be using the second port for spindle control, I'd just wire it directly.
  10. #9
    with the help of a friend the v4 board is now connected and motor is spinning
    but im having a new dro issues in mach.
    motors are 200 steps / revDirect drive, no gearing.Lea
    dscrew is 3mm pitch (1 rotation moves 3mm) waiting to get exact pitch from denford forum
    Microstepping is 1/10 (stepper drivers are set to 10)
    so:No. of steps per mm is = 200 * 10 * (1/3) = 667
    but when I put 667 into steps per in mach the actual machine moves 550mm but I only get a reading of about 26 on the dro
  11. #10
    Your maths seems good.
    What do you mean you only get a reading of 26?
    What are you actually commanding?
    And do you really mean 550mm?
  1. FOR SALE: Denford Starmill ATC
    By andy_con in forum Items For Sale
    Last Post: 14-02-2016, 10:16 PM
  2. 1999 Denford Microrouter problems
    By D-man in forum Denford Routers
    Last Post: 21-03-2015, 12:43 PM
  3. Denford MicroRouter Compact, what to do next?
    By paul_m in forum Denford Routers
    Last Post: 08-01-2015, 09:51 AM
  4. FOR SALE: Denford cnc
    By john legge in forum Items For Sale
    Last Post: 17-03-2013, 11:18 PM
  5. Denford CNC MicroRouter
    By mekanik in forum Milling Machines, Builds & Conversions
    Last Post: 27-08-2012, 06:57 PM
