29-08-2016 #191
29-08-2016 #192
DXF attached for a square button tag, the font is Arial BTW
Button Tag Square.dxf
The Following 3 Users Say Thank You to Davek0974 For This Useful Post:
01-09-2016 #193
01-09-2016 #194
01-09-2016 #195
Very nice again Dave. How come you did not put some grad marks on the feed and speed
I have made a few for mine but cut them out just with the 60' V cutter. Saves changing tools.
Did you use Bold ArialLast edited by Clive S; 01-09-2016 at 10:28 PM.
02-09-2016 #196
Grad marks would be meaningless i thought as its based on the screen display not any real position so i didn't bother, i can always redo them i guess one day ;)
Yes it was Arial Bold and a v-carve path
05-09-2016 #197
Anyone have any views on what sort of speed and acceleration i should be aiming for?
Bearing in mind it has a relatively low spindle speed, even in aluminium, the feed rates are pretty low, I don't think it's worth going much above 2500mm/min?
I have read that there is a point in acceleration where Mach starts rounding corners etc, is this a known point or just something that can happen at some setting value?
Its currently set for 1000mm/min but that seems quite harsh when you do a rapid, it makes the machine shake a little at start/stop of the move.
05-09-2016 #198
Judging from power servo feeds made for that machine, ~900mm/min is the maximum. i think a machine like that could even reach a maximum of 5000mm/min but with slow acceleration. So if servo motors could do the trick of moving it fast, its up to you to decide the balance between speed and acceleration, depending on what you would be doing.
I have to ask Jeff who has a servo driven similar machine, but as far as i remember once he told me, he doesn't push it more than 500mm/min ever.
So no point of making it run away from your workshop if not needed. I would leave it like that / ~900mm/min / and with normal acceleration. Then with the time you know it better you could fine tune it.
Whats your acceleration set at?Last edited by Boyan Silyavski; 05-09-2016 at 04:12 PM.
05-09-2016 #199
It needs to be a bit faster, i have tool paths that run 1150mm/min, i think 2500 may be a good compromise. The servos themselves will easily push it to 7500mm/min if i let them but it is very scary.
I will try my usual 1/10 rule - 2500mm/min and 250 acceleration and see how it goes i think.
05-09-2016 #200
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
