Page 2 of 42 FirstFirst 123412 ... LastLast
    Good points, thanks.
    By direct, I gather you have the screw nut coupled to the front where the depth-stop used to sit?
    It's slippery slope and quickly your into it $$$ before too far to stop.!! . . . Don't Do it Listen to John S.
    awww, bum, damn that cold hard logic JAZZ ;)
    In my defence, it would pretty much fit in with exactly what i want though!
    So, the alternatives then -
    Find a donor machine and hopefully just fit the electrics?
    Downsides I can see...
    space - nowhere to put it.
    would like a big table again - this seems to mean a big machine (see point above)
    transport costs
    unknown wear & tear
    different tooling probably
    This seems not too bad, but its bed is quite small, although it does have an ATC - would that be the sort of stuff to search for???
    http://www.ebay.co.uk/itm/1821213470...%3AMEBIDX%3AIT
    Yep I'd take that every time over converting BP.
  5. #15
    Hmm, looks like a no-go then - it weighs 4,500kg and has a 7.5kw spindle - i could not get that sort of power in the shop and anything much heavier than BP would be a bitch to get into place.
    The bed is poor too - 500x600 not much bigger than my mini-mill!
  6. #16
    Can't beat fat lass with bit of muscle.!!! . . . . But ye got to be practicle. .
  7. #17
    That's the thing - I know mass rocks when it comes to machines, and also see the point of having a pre-ballscrewed donor but as you say - I need to be practical if I bother to do this.
    It would have to be viewed as what it is - a computer controlled Bridgeport Knee Mill NOT a VMC wannabe. I really can't squeeze anything much bigger than a BP in and have no expansion options as we are residential so have to be careful a bit ;) There is no garden left to build a bigger shop.
    In the past I have had bigger stuff - a Colchester Student lathe, a large horizontal mill and a vertical slotting machine - all the stuff i used when building traction engines for fun. Back then I would have killed for a CNC bridgeport but had neither the cash or the knowledge. Using a boring head to machine a 25mm hole out to 100mm and only being able to take small cuts gets old real fast - that job would be seconds with CNC ability.
    I'm still not convinced and a bit pissed that the machine I linked to above costs less than the ballscrew kit alone :(
  8. #18
    Why don't you trade your Bridgeport in for a Bridgeport interact and convert that to Mach3?
  9. #19
    Quote Originally Posted by jamesgates1000 View Post
    Something like this???
    http://www.ebay.co.uk/itm/Bridgeport...sAAOSwYmZXD2Iq
  10. #20
    Looks like a pretty good deal, I have used them before with the heidenhain control and they are good machines. Best wait for some advice from the others regarding suitability for Mach3 conversion.
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
