Thread: Steper motor rumbling
15-05-2016 #1
Hi all I 've rewired a plasma table I now have a problem now the z motor is rumbling now when it supost to be moving (not when at a stop)it seems to be fighting to move but won't move at all.
Sent from my SM-G361F using Tapatalk
15-05-2016 #2
See where you got the name, sounds to me as if motor is wired incorrectly double check your wiring or post some pics of motor and driver with motor and driver details.
15-05-2016 #3
Your funny. The wires match the pins and ports wires for step and direction
15-05-2016 #4
you need to give more information, without more information, it is unlikely anyone will know how to help you.
15-05-2016 #5
What about the wires between driver and stepper? Is each phase wired up correctly? It can damage the driver if incorrect or direct short. Are they series or parallel ?
15-05-2016 #6You think that's too expensive? You're not a Model Engineer are you? :D
22-05-2016 #7
Got sorted the wire was broken
22-05-2016 #8
22-05-2016 #9
22-05-2016 #10
Help setting up Ethernet Smooth Steper
By Tenson in forum General DiscussionReplies: 23Last Post: 19-10-2015, 06:01 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Threaded bar, steper motor and a plasma cutter.. your thoughts?
By gr8fun in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 27-11-2012, 05:14 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
