    I saw this on the 'tube today and after reading all the build and design threads on here I thought it might be interesting to those builders.
    This is built with 1/2" steel box frame and is every bit as good as a production unit...
    https://youtu.be/b-y03hhCCME
    I would love one of these.
    We should consider that he used a VMC-15 to machine stuff for it and has what we might consider an unlimited budged though ;-)
  3. The Following 2 Users Say Thank You to magicniner For This Useful Post:
    Yes, also worked for Haas ;) And built it in 8 weeks!
    BUT, at the end of the day, it is made from steel box, HiWin rails and ballscrews - stuff we play with all the time.
    I think it just shows that basic stuff can build seriously good machines.
  5. The Following User Says Thank You to Davek0974 For This Useful Post:
  6. #4
    He was a founder of FADAL, not Haas ;)
    And it's not quite bog standard steel box. IIRC it's a high tensile cromoly steel.
  7. #5
    My bad ;)
    I still thinks its a cool machine though, yes he used big machines to build it but then we could send a frame out for machining to big company - it's not that expensive.
    Yes the steel is cromoly but that is available.
    The motion was bog-standard HiWin though, most likely with pre-load etc but still HiWin.
    He just copied a production machine and scaled it down, but it proves it can be done without throwing three hundred tons of steel at it ;)
  8. #6
    One of the key ingredients was was the budget, another was a VMC big enough to make major parts, and to face up and square the mounting points on the weldments.
    I don't think the workshop facilities he has can really be included in "basic stuff" ;-)
  9. #7
    If we all had the same resources he had our machines would be better, mine was built using a micro mill less than £500 new with a £100 conversion and no previous experience. His workshop and his budget I would have built a better machine than I did and in your case I would guess your mini mill would have grown and had that £4k ATC spindle.
  10. #8
    Don't get me wrong here, I think what we have all built or are contemplating building here are simply fantastic, what I am trying to say is that the frame for his build probably did not cost that much, yes he has a whole lot of bells and whistles added but at the core it's just an L-shape steel box frame and I would wager that it could be done a lot cheaper than his and still get the results as the design is sound and shows that mass is important - his bed must weigh a fair bit alone.
  1. AMAZING Machine Shop Tour: Berkeley Lab with Tom Lipton!
    By Lee Roberts in forum Workshop & Equipment
    Last Post: 23-02-2016, 11:59 AM
  2. Replies: 0
  3. Amazing!
    By oscar in forum General Discussion
    Last Post: 28-10-2012, 05:12 PM
  4. Replies: 1
    Last Post: 22-07-2010, 10:50 PM
