Thread: Z axis moves below set zero
28-05-2016 #11
28-05-2016 #12
I tried to load a video the z just keeps moving down past 0 and keeps going on down levels out eventually
Sent from my SM-G361F using Tapatalk
28-05-2016 #13
28-05-2016 #14
28-05-2016 #15
28-05-2016 #16
28-05-2016 #17
Hk
28-05-2016 #18
Woops tried to delet made it worse
28-05-2016 #19
N0010 (Filename: nigel first flange final.tap)
N0020 (Post processor: Mach3.scpost)
N0030 (Date:24/05/2016 Time:01:13:16)
N0040 G21 (Units: Metric)
N0050 G40 G90 G91.1
N0060 F1
N0070 (Part: nigel first flange)
N0080 (Operation: Outside Offset, 0, T1: Plasma, 0 mm kerf)
N0090 (Plasma, 0 mm kerf)
N0100 T1 M06
N0110* G43 H1
N0120 G00 Z20.0000
N0130 X95.8839 Y95.8838
N0140 Z10.0000
N0150 G01 Z1.500 F100.0
N0160 F440.0
N0170 X94.1162 Y94.1161
N0180 G00 Z20.0000
N0190 Y95.8839
N0200 Z10.0000
N0210 G01 Z1.500 F100.0
N0220 F440.0
N0230 X95.8839 Y94.1162
N0240 G00 Z20.0000
N0250 X95.0000 Y20.0001
N0260 Z10.0000
N0270 G01 Z1.500 F100.0
N0280 G03 X95.0000 Y20.0001 Z1.5000 I-0.0000 J74.9999 F440.0
N0290 G00 Z20.0000
N0300 X94.6339 Y4.9339
N0310 Z10.0000
N0320 G01 Z1.500 F100.0
N0330 G03 X94.6339 Y4.9339 Z1.5000 I0.0000 J4.6999 F440.0
N0340 G00 Z20.0000
N0350 X155.9880 Y29.3121
N0360 Z10.0000
N0370 G01 Z1.500 F100.0
N0380 G03 X155.9880 Y29.3121 Z1.5000 I0.0000 J4.6999 F440.0
N0390 G00 Z20.0000
N0400 X182.1339 Y89.9339
N0410 Z10.0000
N0420 G01 Z1.500 F100.0
N0430 G03 X182.1339 Y89.9339 Z1.5000 I0.0000 J4.6999 F440.0
N0440 G00 Z20.0000
N0450 X157.7557 Y151.2880
N0460 Z10.0000
N0470 G01 Z1.500 F100.0
N0480 G03 X157.7557 Y151.2880 Z1.5000 I0.0000 J4.7000 F440.0
N0490 G00 Z20.0000
N0500 X97.1339 Y177.4339
N0510 Z10.0000
N0520 G01 Z1.500 F100.0
N0530 G03 X97.1339 Y177.4339 Z1.5000 I0.0000 J4.7000 F440.0
N0540 G00 Z20.0000
N0550 X35.7798 Y153.0558
N0560 Z10.0000
N0570 G01 Z1.500 F100.0
N0580 G03 X35.7798 Y153.0558 Z1.5000 I0.0000 J4.7000 F440.0
N0590 G00 Z20.0000
N0600 X9.6339 Y92.4339
N0610 Z10.0000
N0620 G01 Z1.500 F100.0
N0630 G03 X9.6339 Y92.4339 Z1.5000 I0.0000 J4.6999 F440.0
N0640 G00 Z20.0000
N0650 X34.0120 Y31.0799
N0660 Z10.0000
N0670 G01 Z1.500 F100.0
N0680 G03 X34.0120 Y31.0799 Z1.5000 I0.0000 J4.6999 F440.0
N0690 G00 Z20.0000
N0700 X95.0000 Y-0.0000
N0710 Z10.0000
N0720 G01 Z1.500 F100.0
N0730 G02 X95.0000 Y-0.0000 Z1.5000 I-0.0000 J95.0001 F440.0
N0740 G00 Z20.0000
N0750 M05 M30
28-05-2016 #20
A mental speeds is too high warring just came up
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
problem: y-axis only moves in one direction using TB6560 board off email
By polysoul in forum Machine DiscussionReplies: 9Last Post: 08-06-2012, 12:12 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
moves ok when using jog in mach3 but....
By deannos in forum General DiscussionReplies: 2Last Post: 28-12-2011, 09:40 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
