Thread: over kill?3040 fixed gantry cnc
i might have got a bit carried away with my new revised version of a fixed gantry...its a 3040 sized work area for milling plastics and aluminium, box section is 100mm x 100mmx 5mm sat on the rack at work.
and im hoping my gaffers will help us out with using their laser cutters with the plate.
still loads to.
30-10-2016 #2
It wouldn't be right if I didn't mention the blinking obvious, you are under no obligation to listen though.
The profile rails are upside down. You should have the rails bolted to the table and the carriages bolted to the gantry.
The way you have it makes for an unnecessary overhang which you are trying to compensate with huge box sections.
ta lads.
i dont think ive ever seen an x axis arrangement in the way you describe robin
30-10-2016 #5
Robin's usual suggestion is quite common on milling machines, including mine. It makes sense so long as the bed is very strong, though it's not normally seen on extremely high precision machines as the weight of the overhanging will cause some deflection, but that's hardly a concern to us.
Careful with the bearing spacing you've chosen for X - with a single ballscrew either the bearing spacing should be increased or the rail spacing decreased, else the stiffness of the X-axis is reduced when Y is towards either extreme.
By the way, when it comes to aligning the rails and bearings, I have a quite high precision straight edge and square now, so you're welcome to borrow them.
Fixed z axis to gantry design
By Lachlan in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 20-10-2015, 09:50 PM -
FOR SALE: fixed gantry router/mill up for grabs
By dazza in forum Items For SaleReplies: 9Last Post: 12-03-2015, 11:15 PM -
BUILD LOG: Monster fixed gantry router for aluminium & wood
By jonboycnc in forum DIY Router Build LogsReplies: 9Last Post: 12-01-2014, 11:26 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
BUILD LOG: Fixed Gantry Router
By lateAtNight in forum DIY Router Build LogsReplies: 24Last Post: 28-05-2009, 11:30 PM
