Thread: Nema 23 smooth shaft mountings?
02-05-2017 #1
Hi, I recovered 2 nema 23's from a printer they had cogs pressed onto them I had to use a hydraulic press to remove the shafts (They were on so hard it broke the m5 stainless steel bolt I first tried to use so had to use an m6 which bent but did manage to release them eventually.
The motors work fine so I was wondering about coupling to my ballscrews when they arrive, my nema 17's have a flat spot on the round shaft to increase grip when mounting the motor's.
Should I
1. Try to file the motor's shafts down?
2. Not file the shaft down and use the couplings as is with the round shaft? This is easiest but how much will it affect power or skipped steps?
3. Have some new couplings custom made with the motor mount side a tight fit and hydraulic pressure fit them to the motors?
Thankshttp://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
Should I
2. Couplings like these https://www.aliexpress.com/item/A106...485607827.html can be used.
3. Press fitting is not a good idea.
Have you thought about keeping all your questions in one place on the build log that would make it easier to keep track of. Good luck with the build...Clive
FOR SALE: 3 x 8 wire nema 23's 8mm dual shaft bi-polar parrallel 76mm
By nobby in forum Items For SaleReplies: 0Last Post: 18-01-2015, 11:15 PM -
WANTED: 2 nema 23's 76mm long dual shafts 6.35mm plus one 56mm long nema 23 dual shafgt 6.35
By nobby in forum Items WantedReplies: 0Last Post: 24-09-2014, 09:57 AM -
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
WANTED: 3 nema 23's 76-81 or 86mm long, 8 wire - shaft each end - turn wheels, if 8mm out...
By nobby in forum Items WantedReplies: 1Last Post: 11-06-2013, 09:51 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM
