11-03-2017 #1
11-03-2017 #2
BK is Fixed end and consists of of 2 angular contact bearings held and preloaded within the housing. The photo shows all sizes depending on end machining and screw diameter. IE: Bk12 being used for 16mm screws Bk15 20mm etc.
BF is the floating end and just uses normal bearing which floats within the housing and is held onto the ballscrew with a Circlip.Last edited by JAZZCNC; 11-03-2017 at 08:46 PM.
11-03-2017 #3
11-03-2017 #4
Well it's knock off then because should have 2 x AC bearings which go back to back. It used to be common on the really cheap ones that the bearings where in the wrong way around so didn't work correctly allowing slop but still used AC bearings. Never seen one with skate board bearings before.!
11-03-2017 #5
Dam and i paid 260 inc postage of a ebay guy in Germany
11-03-2017 #6
12-03-2017 #7
Yup got fleeced like that once too: 6001zz in the bearings blocks and paint inside the bore to hold the bearings in place...
https://emvioeng.com
15-03-2017 #8
After many emails i got given 6 angular contact bearings, hopefully this is a lesson for everyone to ask what bearings are fitted !!!
WANTED: BK12 Bearing Block Wanted - 1 off
By EddyCurrent in forum Items WantedReplies: 7Last Post: 11-03-2017, 08:52 PM -
Experience with fixed - fixed ball-screws vs fixed - supported?
By PotatoMill in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 16-05-2016, 08:37 PM -
Hiwin guide rail bearing block HGH20CA installation help
By ba99297 in forum Rails, Guideways & BearingsReplies: 6Last Post: 12-07-2014, 09:23 PM -
BK12 end float?
By birchy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 20-07-2013, 02:28 AM -
Understanding the bearing block
By Rogue in forum Rails, Guideways & BearingsReplies: 10Last Post: 28-08-2011, 03:14 PM
