Thread: HIWIN Grease Fitting Extension
01-05-2017 #1
Just got around to doing some general maintenance on the router recently and found that I had messed up on the Y-Axis design, by not leaving enough space to access the grease fitting:
I don't really want to start disassembling things to get temporary access, as everything's lined up/trammed nicely now - so was wondering if anyone knew of a way so that I can grease this in it's installed position? Maybe some sort of ~10mm long M6x1 male to female extension which I could install temporarily in-between the two so that the fitting clears the Y axis base plate enough to get the grease gun onto it?
Cheers,
Raz
01-05-2017 #2
Grease nipple extensions are fairly standard. Getting one should be simple enough. If you have a lathe they are very easy to make.
01-05-2017 #3
02-05-2017 #4
I think we used Moore international for the stuff we used at work but I made some at home because they were a lot cheaper. How many do you need?
02-05-2017 #5
02-05-2017 #6
Whilst searching for Moore International on google, I ran into these guys. http://shop.hle.co.uk/shop/grease-eq...on-pieces.html
Seems to do the job (as long as the hex head doesn't clash with the rail) so will give them a go. Cheers.
03-05-2017 #7
The hex should be the same size as the standard nipple nut so it should fit ok. Glad you all sorted now.
The Following User Says Thank You to Web Goblin For This Useful Post:
03-05-2017 #8
I went looking for a kit .. no luck but did find this http://www.ebay.com.au/itm/Y-8-4mm-D...-/322132683954
Next stop his Hi-Win data sheets
03-05-2017 #9
03-05-2017 #10
We have both manual central lube systems and auto lube systems installed on some of our machines at work. Both work well but I prefer the manual lube, as long as the operators remember to use them at the start of their shifts. The issue I have with the full auto lube system is over greasing. Apart from them supplying grease at their timed intervals they also supply grease when they are powered on to start their cycles so this means that every time we have an emergency stop situation with either a light guard being broken or collision sensor operating the auto lube restarts it cycle when the power has been restarted. We can have quite a few extra grease operations during shifts.
4 pin extension leads
By GaryWilliams in forum Chinese MachinesReplies: 11Last Post: 24-12-2021, 12:27 PM -
Do you grease HiWin rail Sliders?
By AndrewMawson in forum Linear & Rotary MotionReplies: 2Last Post: 09-01-2017, 04:15 PM -
.GD4 file extension ?
By greenz123 in forum CAD & CAM SoftwareReplies: 7Last Post: 30-06-2015, 12:44 PM -
Ballnut Lubrication / Grease
By Mad Professor in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 18-07-2012, 08:08 PM -
Limiting unsupported extension on Zaxis.
By Rogue in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 03-09-2011, 12:30 AM
