Guys,
Hoping someone can help?
I have just purchased VCarve Destop software and going through the video tutorials.
Every time I create a project either from following the tutorial or my own very simple project the cutter dives down to .5".
I have set up a simple pocket cut of 0.125 and every time the cutter follows along the pattern but 4 times the depth.
I'm using UGCS, xPro Controller V3 and VCarve Desktop. Post processor used in VCarve is G Code (inch)(*.tap)
Would appreciate any ideas or thoughts as I am well and truly stuck.
regards
Tony
Sounds like you need to check the motor setting in Grbl see here: https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.9
13-12-2017 #3
Thanks Phill05.
I have now checked the settings and can't see anything striking.
I have now run a small cutout pocket created in MakerCam. This runs fine, so my attention I think is the post processor in VCarve.
Anyone running VCarve or Cut2D I would be interested in knowing what Post processor you are using.
You should be okay with G Code (inch)(*.tap) or G Code (mm)(*.tap) are you drawing and saving toolpath in Inch or mm?
13-12-2017 #5
Tried those settings also GBRL both inch and mm.
No idea what is going on
14-12-2017 #6
An update.
I run the same small pocket test design with Cut2D this worked fine. With both MakerCam and Cut2D working okay the finger firmly points at VCarve. Both Cut2D and VCarve are Vectric pieces of software. My thoughts turned to application conflicts so I uninstalled both Cut2D and VCarve. I then reinstalled VCarve and run the test again, this time it worked perfectly.
It looks like Vectric cannot work with 2 applications installed. Thanks Phill05 for your suggestions.
Looking for an CNC xPro controller board
By centurian in forum Spindles & Drive MotorsReplies: 21Last Post: 21-09-2018, 10:03 PM -
VCarve pro problem?
By D-man in forum VectricReplies: 3Last Post: 23-08-2015, 07:49 PM -
vcarve pro 7
By GeoDurie in forum CAD & CAM SoftwareReplies: 3Last Post: 22-05-2014, 02:46 PM -
Motor controller next to break out board?
By m_c in forum General ElectronicsReplies: 2Last Post: 17-11-2010, 01:56 PM -
Controller Board Getting Very Hot / Allegro A3977
By MikeVA in forum Motor Drivers & ControllersReplies: 11Last Post: 08-09-2008, 03:04 AM
