Thread: For Sale : Steel frame
12-08-2018 #1
I've done a lot of soul searching and come to the conclusion that I haven't got the space for my planned router - so I've bought a mill and will be doing a CNC conversion with that, and using the steel bench that I'd made for the router as a generic bench for the mill and my old Denford (addresses my mixed needs for spindle speeds with having two machines).
As a result, I have the steel frame that I was going to use for the rails - welded construction from 90x90x3 steel, fairly square and flat (flat enough for an epoxy bed for the rails). Size is 1400mm x 730mm (external), there're 4 9mm holes drilled - two either end along the short sections.
One long section is drilled and tapped M5 x 60mm centres to mount a 1m linear rail, there's one similar drilled/tapped hole on the other long section (I'd got as far as mounting and aligning the rails).
Could do with a wipe down with acetone - you can see the sticky outline of the tape I'd used to dam the epoxy - which I've removed (there was a couple of sections which weren't mixed correctly and the surface there never set).
Clearly, a very bespoke bit of iron. Cost me > £100 to fabricate, but I realise that there's little value to a third party. I'm prepared to let someone pick-up for free if you can use it, but please understand that I could drop it off at the tip and be back home before my cup of tea went cold - so don't make it a chore for me. Collection from Preston Lancashire. It's currently outside the shed, so will be growing rust.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
Steel Frame 8' x 5' CNC - Advice Sought
By BrentonSpear in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 01-06-2015, 11:12 AM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
Steel frame for 8' * 4' cnc bed ?
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 24Last Post: 18-10-2011, 08:57 PM
