Page 2 of 2 FirstFirst 12
    it's up to higher-level protocols to manage the error handling.
    Given the lack of support for Banyan Vines, Token Ring and other legacy networking protocols, what's the chance of using Ethernet without TCP/IP and all it entails and thus what's the point of that point? :D
    The point of that was to address an earlier comment that Ethernet provides error correction - which is certainly not a part of the lower comm layers. In fact, TCP/IP doesn't provide error correction - merely a retry mechanism.
    TCP/IP isn't the be-all/end-all. For the last few years I've been involved in an engineering activity centred around UDP.
    :D
    Funny, I never get a failed/partial file download because of missing packets ;-)
    I think you're pointing out the minor shortcomings in a system which have no impact whatsoever on the application being discussed :D
    Downloading of files and handling of hard disk is not real time activity so packats can be resent any number of times. The checksum of the file and the packets will tell you if there is a need for resend.
  5. #15
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    Smilies are wasted on some people :D
  6. The Following User Says Thank You to m_c For This Useful Post:
  7. #16
    Very true.
    They also tend to use technical arguments which they patently misunderstand to prove that something which works very well ought not to :D
  1. Pci or Ethernet motion control?
    By Ross77 in forum Machine Control Software
    Last Post: 16-10-2019, 08:27 PM
  2. Any USB/Ethernet controller suggestions?
    By jtar40 in forum Motor Drivers & Controllers
    Last Post: 15-05-2019, 07:58 PM
  3. WANTED: Ethernet Smooth Stepper
    By davidimurray in forum Items Wanted
    Last Post: 08-10-2017, 02:29 PM
  4. UC300 Ethernet
    By noyloj in forum CNCdrive (UC100, UC300ETH)
    Last Post: 02-01-2017, 10:21 PM
  5. Help mach3 ethernet set up
    By kell in forum Artsoft Mach (3 & 4)
    Last Post: 06-12-2015, 10:26 PM
