Lots of motor drives have an analogue output.
Can anyone tell me what it does, and what it could be useful for please?
Many thanks
Analog output, sounds vague.
Could be a number of things.
Likelyhood is that it is a tachometer or encoder, both of which provide some form of voltage to indicate either speed or position.
How many wires? What does it connect to? If its the rear of the motor, normally this will be for feedback (tacho / encoder).
23-05-2018 #3
23-05-2018 #4
23-05-2018 #5
23-05-2018 #6
http://www.parker.com/literature/SSD...s/HA389427.pdf
(Control terminal number 5 output reference 0-10v)
If it were possible to connect this as a current reference I could use for a load meter that would be great however I can’t find any info in the manual that explains how it would work?Last edited by Toolman321; 23-05-2018 at 06:20 PM.
23-05-2018 #7
It actually says
Control terminal number 5 -- +10V Reference -- Analogue output, +10v Reference for speed and current set points
It's the 10v you connect to one end of a pot, with the other end to 0v and then use the pot variable output to the analogue input for a speed control knob.
There may be other stuff you can use it for but you have to read the whole manual and see what the relevant Parameter settings configure.You think that's too expensive? You're not a Model Engineer are you? :D
The Following User Says Thank You to magicniner For This Useful Post:
FOR SALE: Parts For Sale - Servo Drives, Controller, 3Kw Motor, Transformers
By MrBurns in forum Items For SaleReplies: 0Last Post: 27-01-2017, 06:13 PM -
Drives without steppers
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-03-2014, 01:07 PM -
what are your immediate thoughts looking at this psu/ drives and bob in a box
By nobby in forum General ElectronicsReplies: 9Last Post: 21-02-2014, 09:57 PM -
Stepper Drives
By GTJim in forum Marketplace DiscussionReplies: 4Last Post: 05-04-2013, 12:05 PM -
Help with 3 axis CNC motor and drives
By domagoj55 in forum General ElectronicsReplies: 7Last Post: 04-03-2013, 12:51 PM
