    Need help please, with my Seig CNC. This is an early conversion from Arc. Had problems for some time with the front guard micro switch. So took out the switch and coupled the wires together. Solved the problem and all was well until I accidentally dropped the wires and shorted the main fuse. I can now hear the relay clicking in and out as normal but no spindle movement. If you have any inclination towards a possible solution, I would be extremely grateful.
    There might be a main power fuse blown that feeds the spindle (as well as a fuse in line near the spindle's drive). Are you getting power to the spindle drive?
    Chaz - No just getting the normal audible click on and click off. This is the model with the separate 12v power supply at the back of the column. Having my sparkbuddy check it out in the morning.
    have you asked Ketan @arc eurtrade
    Photos of the speed control board and CNC interface will be useful
    my mini lathe for example has a seig FC250 PWM speed control board with 2 FET's as the control devices
    the board has has two relays that form a no-volt release and interlock that forces you to start at minimum speed
    later machines have a XMT2325 speed control that uses two thyristors as the control devices that are part of a controlled bridge rectifier
    once the various boards have been identified it will be easier to fault find
    John
    John - Thanks for help. I will take some photo`s this morning,
    Rod
    John - Here is photo of board. The two blue wires next to the central small white box are the ones I shorted. The card is marked SEIG MACHINE zz0070201A Click image for larger version.
    I have not found an exact match but this PDF wiring diagram for a
    110V mini lathe gives you a basic wiring diagram
    PDF diagram
    for the CNC conversion
    the speed control potentiometer that is normally connected to terminals p1 to p3 has been replaced by
    a DC control voltage connected to p1 & p2
    without the circuit diagram of the speed control board
    I can not guess what the blue wires are connected to and
    what possible damage to the board could of happened to the board
Name:	speed control board.jpg
    if the under side of the PCB looks OK with no blown tracks
    it will be possible to bench test the board using a 100W bulb as a dummy load in place of the motor and a potentiometer connected to P1 to P3
    NOTE - all the board & the wiring to the potentiometer will be live !!!
    repairing my CL300m lathes speed control board
    https://www.model-engineer.co.uk/for...p?th=38809&p=1
    John
    PS
    found it
    the board is a XMT-2360
    John - Thanks, the board is XMT 2360. The two blue wires are connected to the green chuck guard switch you have indicated. There are currently 3.6V across the terminals.
    Les has details of the XMT-2360 on his web site
    http://lesjhobbies.weebly.com/upload.../pcb_speed.pdf
    if your lucky R17 on page 2 has gone high resistance when terminal K3 shorted to earth
    terminal K4 shorting to earth will be of a problem
    John
    John - If the R17 has gone high. Is there anything I can do?
    Rod
  1. Replies: 6
    Last Post: 20-12-2018, 03:40 PM
  2. Huanyang VFD and spindle problem
    By BriceO in forum Spindles & Drive Motors
    Last Post: 07-08-2018, 08:56 AM
  3. Problem with Spindle not spinning
    By Noplace in forum Spindles & Drive Motors
    Last Post: 22-01-2016, 02:40 PM
  4. seig x3 R8 V MT3
    By dazza in forum Milling Machines, Builds & Conversions
    Last Post: 18-02-2014, 01:14 PM
  5. CNC spindle control VFD problem
    By djc in forum Motor Drivers & Controllers
    Last Post: 13-09-2009, 09:26 PM
