Thread: DIY Surface grinder
A fast ticket to ridicule, according to some bod trying to do it on YouTube, but what care I?
I had this notion that 30mm round rail bolted to RSJ's might just be rigid enough. I looked at what was available and went for 230x75 parallel flange channel at 25 kg/meter. The rails are all 50cm long.
I machined aluminium blocks to connect rail to RSJ. These fit inside the channel. There's a thin slice of channel draped over one of my blocks in the picture.
The idea is that misalignment is irrelevant, it is twist and flex that must be overcome. Do we agree?Last edited by Robin Hewitt; 27-08-2018 at 10:17 PM.
27-08-2018 #2
I guess the YouTube channel you are referring to is ‘physics anonymous’ ? They are trying to build a homemade grinder but there has not been an update for a while.
I’ve been thinking about your question of whether alignment is relevant and it feels wrong but maybe you are right and it does not matter.
On the stiffness then as you say that will matter as the work piece will be pushed away rather than being ground and the effect will be different depending on where the table is on the rails as they are stiffer at the ends of travel. So the workpiece would not be flat but would be dished in the middle. Any reason you did not go for supported rail or linear profile rail?
Good question. I reasoned that profile rails and supported rails conform to whatever you bolt them to, but round rails have their own built in straightness. By bolting the X and Y blocks either side of the same plate, I think I have defined a flat XY plane and I can grind the table square to that.
The tricky bit is cutting the inside of the RSJ channel flat and square where the rails connect. There is no sensible reference surface anywhere, tolerance seems to be about 1.5mm. I am hoping for consistency.
I got a wonderful gadget from RDG Tools, a sort of spring loaded centre. This held the m30 reamer amazingly square and true when finishing the end supports. I can slide all 6 onto the same pair of rails and they happily slide about and butt up against each other. I was not expecting that, good tool.
30-08-2018 #5
Before you spend any more time and money i would look at Dronsfield Eagle manual surface grinders (i paid £250 for mine) or Herbert made some small machines. If you have more space a Jones and Shipman 540 is best value. It may take a while for to find one on Ebay that suits your purpose. Even the small machines are 300Kg plus.
30-08-2018 #6
What size and orientation of wheel is planned?
30-09-2018 #7
Oh , yes, very good
Here are a few questions I am pondering...
One of the best features of CNC surface grinders is that once you diamond dress the stone you know the exact height of it above the chuck. Is that information worth preserving for the next session? I'm wondering if the ON/OFF switch should apply a precision brake to the Z screw before cutting the power.
Do I need to seal all the workings dust tight or will the wipers already fitted on the linear bearings and screws suffice?
Do I need to machine the inside of the RSJ flat, to square off the rails, or will the rolled stel consistency compensate for the rolled steel innaccuracy?
01-10-2018 #9
The coolant/grinding wheel/ground metal, produces a very fine grinding paste so if wipers did work it would not be for long.
This is the minimum spec machine in terms of safety and ability to grind. It may be cheaper to buy a complete machine that needs a rebuild and fit motors on the handwheels. I paid 250 for mine and magnetic chucks on there own will not cost much less.
https://www.google.com/search?q=dron...1ZWXccBbiMtKM:Last edited by Colin Barron; 01-10-2018 at 03:43 PM.
Surface Grinder - Elliott 618 - Any Good?
By Chaz in forum Metalwork DiscussionReplies: 2Last Post: 30-08-2018, 01:51 PM -
Spec me a grinder/belt for finishing aluminium.
By JOGARA in forum Workshop & EquipmentReplies: 27Last Post: 17-10-2017, 02:20 PM -
NEW MEMBER: From grinder to 3D printing to CNC
By laranjas3 in forum New Member IntroductionsReplies: 2Last Post: 12-10-2017, 06:59 AM -
Centerless grinder LOESER RPS 374 - in Europe
By Grinder in forum Opportunities Available & SoughtReplies: 1Last Post: 24-11-2014, 04:53 PM
