    X & Y Ball Screws, Ball Screw mountings, End Bearings and lubrication for X & Y Ball Nuts completed -
    Y-Axis assembled, assembling X-Axis, oil system in, nearly ready to fit the table.
    Once the table is fitted it's time to see what needs doing with the column :D
    Table fitted.
    Column stripped, offering up the Ball Screw and Ball Nut Assembly and working out what's required to connect the Ball Nut Assembly to the vertical slide.
    I'm leaning towards a solid connection to the vertical slide rather than the "Peg and Socket" arrangement used in the standard column assembly.
  1. CONVERSION: Chester 626 milling machine conversion.
    By RobWilson in forum Conversion Build Logs
    Last Post: 23-04-2018, 08:14 AM
  2. NEW MEMBER: hello from chester
    By crazynight in forum New Member Introductions
    Last Post: 06-03-2016, 11:48 PM
  3. NEW MEMBER: Hello from Chester UK
    Last Post: 05-03-2016, 03:31 PM
  4. NEW MEMBER: Hello from Chester
    By PWD in forum New Member Introductions
    Last Post: 25-05-2012, 07:42 AM
  5. Chester tools champion 16v milling machine conversion
    By NICKMODELMAKER in forum General Discussion
    Last Post: 26-02-2010, 09:29 AM
