    I have saved calibrate settings with x,y,z step/unit.. I have now uppdate my windows to version 10
    I find that my saved calibrated setting doesnt work.
    What shall i do.Shall i simple calibrate axels again,or is there another explanation.
    thanks for your advise.
    Why did you update?
    If it isn't broke don't fix it.
    I hate windows 10 with a passion.
    You'll have to try setting it all up again. If it works, then great. If it don't, then go back to win7.
    Surely you mean CNC USB motion controller not stepper driver.? they are very different things.
    However in both cases just changing operating systems shouldn't alter any settings and with both operating systems you would use the same Steps per setting as these have nothing to do with the OS.
    If it's not working the easiest thing to do is just start again but your question is a little light on explaining exactly what is not working.? Does it work but doesn't move correct distance etc or does it not work at all or some does it do some other weird and wonderful thing.?
    If not at all then it's very likely it may not work with win10 or you need updated software or plugins to work with win10 and it's nothing to do with your settings being wrong.?
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    I'm going to go out on a limb, and guess this is a Planet CNC board.
    And being MK1, I wonder if it's genuine..
  1. Bridgeport interact 316 Operation Manual
    By wojtekthx in forum Bridgeport Milling Machines
    Last Post: 23-10-2016, 10:22 AM
  2. Boxford TCL160 turret operation
    By Saracen in forum Boxford Lathes
    Last Post: 22-10-2015, 11:58 AM
  3. Simple lathe operation?
    By gavztheouch in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 08-10-2014, 08:32 PM
  4. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  5. BUILD LOG: operation cnc
    By kingcreaky in forum DIY Router Build Logs
    Last Post: 14-08-2013, 06:14 PM
