18-12-2014 #342
Well maybe not, this is the thread, also read a few pages earlier; http://www.mycncuk.com/threads/6619-...3914#post63914
19-12-2014 #343
Yeah I've read it....my pour went OK apart from a couple of leaks which I cured and me not having the correct ratio. I got no shrinkage and the epoxy was level all round (measured with a straight edge and level) so I'm going to go as I did before. Mine is only 1300mm long so no where near the length of Boyan's which I think is where alot of his problems came from.
19-12-2014 #344
Finished the moat today, another day of only 1/2 hour to work on the machine. Still ill not be rushing!!!
Built it with tabs so that I can lift it off and replace it easily after running a bead of sealant under/round it to seal the gaps. Started gluing the mdf with superglue but ended up using no-nails...will put some oil on the MDF first so the epoxy doesnt stick (as much) to it.Last edited by njhussey; 19-12-2014 at 05:59 PM.
19-12-2014 #345
19-12-2014 #346
Yes, i was going to use that...Trouble is there's some oil already on it so the parcel tape won't stick...
Nope not taking any chances...going to triple check everything!!! ;)
Neil I used the Wests System and found it easier to weigh out the two parts with a digital scale rather than by volume and mixing with a flat paddle (strip of ply etc) if this helps. Good luck. ..Clive
19-12-2014 #348
21-12-2014 #349
Do you have access to a vacuum pump? IF so, you can put the well mixed resin in an over sized container and degas that way (a sealed 50 gallon drum can act as a chamber if the pump can handle the volume). That gets rid of pretty much all gas in the resin which will make for a much better pour and no worry over bubbles. The issue is getting access or having a vacuum pump that can handle the volume.
MichaelSoftware SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
Or a drum that can take a vacuum .. Clive
There are currently 15 users browsing this thread. (0 members and 15 guests)
BUILD LOG: A3 Router Build
