    Chas's Avatar
    Lives in Nottingham(ish), United Kingdom. Last Activity: 09-03-2013 Has been a member for 9-10 years. Has a total post count of 55. Received thanks 2 times, giving thanks to others 2 times.
    Does anyone know of an individual or company offerring on-site electrical repairs to machinery in the Notts/Derby area?
    I have a Seig CQ6230B lathe that went bang a couple of months ago & my very limited knowledge of lecktricity is not helping to get it up & running.
    The 240-24v transformer definately burnt a wire but replacing this hasn't solved the problem, I think something else, possibly a contactor is faulty which caused the transformer to burn out.
    It's a single phase 240v machine with 24v controls running a 1.5kw single phase double capacitation induction motor.
    I don't know if it'll take a man who knows 2mins or 2hrs to diagnose but it'll take me 2yrs+ to learn lektronix from scratch. I've put the lathe up on castors so it can be easily wheeled around for access.
    You are my only hope, I have work waiting for it but it's just scrap metal at the moment & far too heavey for me to chuck it out of the window :-)
Name:	Control Box 1.jpg
    Chas
    If the whole unit will not power up or just trips straight away, you have no bare wires then suspect the transformer itself. If it is only part of the lathe that does not work then it would be the contactor for that circuit (normally just the energising coil). There is not a lot that can really go wrong, i'm wiring a new lathe up from scratch at the moment myself. What does each contactor feed? tell us more about the controls? is the contactors controlling motor, pump, light etc?
    Chas's Avatar
    Quote Originally Posted by 2e0poz View Post
    Chas
    In my picture from left to right.
    Contactor 1 = motor forward
    Contactor 2 = Motor reverse
    Contactor 3 = coolant pump
    Contactor 4= unknown
    I've just found out that pushing in the contactors gets the motor running regardless of the lathes forward/reverse switch.
    When I switch the lathe on, there is no 'clunk' like there used to be.
    Is contactor 1 at fault?
    Chas's Avatar
    First electric shock, luckily only 24v.
    A small crowd is gathering . . . . I might make some smoke before the day is done.
    Ok if you have 24v showing the transformer may be ok? not sure why there is a need for a separate contactor between forward and reverse? will it run in reverse ok? if yes the the first contactor is duff (assuming the second contactor does not get fed from the first). Try swapping the first contactor with the second (make notes of all the connections as i see somebody has taken the trouble to number them). To replace all these conmponents would be cheaper to do than call somebody out and pay for the parts on top as well so consider a trip down to the electrical factors. Is the machine 3 or single phase?
    Consider 230v contactors and do away with the 24v transformer? you may even be able to get new coils on there own for the contactors if they are removable.
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    230V contactors are not a good idea!
    24V is far safer for controls.
    And the seperate contactors for forward/reverse are to rewire the start capacitor so the motor starts up the opposite way, that way you don't have 230V at any of the control panels.
    Have you got access to a multimeter?
    And was there any fuse on the 24v side of the transformer?
    With the right switch there is no need for a separate contactor with appropriate circuit protection, it should not make any difference whether it is 24v or 230v. The circuit i used for my mill works with a single contactor no trouble at all on 230v coils.
    If they have gone to the trouble of adding lots of contactors whether there is one for a brake on the motor? does one exist?
    And by the time you find/buy new switches and contactors, and change the wiring, it'll be the far more expensive option.
    You say there was a burnt wire. Where did it go to/from?
    Chas's Avatar
    The burnt wire was in the transformer itself, it's all the visible evidence I can find. I've got a replacement transformer of the same values but it's too big to fit inside the box, I'm having to temp wire it up outside untill I can find the right sized one.
    The only fuses (other than the 13amp plug) are the MCB's, none blew or tripped.
    I've got a multi-meter but don't really know how to use it, I'm OK at ID'ing what voltage from what wire & continuity etc but please don't ask me to start measuring OHMs or amps etc.
  1. Honey I blew up the mini lathe speed control board
    By HankMcSpank in forum General Electronics
    Last Post: 23-01-2018, 09:39 AM
  2. Mach lathe spindle speed control
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 21-05-2014, 08:34 AM
  3. Bent ballscrews - is repair possible?
    By bee in forum Lead Screws, Nuts & Supports
    Last Post: 10-12-2013, 09:41 PM
  4. RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
    By Chas in forum Projects, Jobs & Requests
    Last Post: 07-11-2010, 09:28 AM
  5. CNC repair
    By 2006Nobull in forum Machine Discussion
    Last Post: 05-10-2010, 11:25 AM
