Thread: Starmill
07-01-2011 #21
Yes, you would need three of these circuits one for each drive, and no the breakout board does not give you this feature.
It's a simple circuit that you can pop on a small piece of veroboard and connect it between the breakout board and Parker stepper drives.
07-01-2011 #22
Componants for 4 boards orderered (1 spare) I'll get soldering when they arrive. Not quite sure how to connect up or what my next stage is though.
07-01-2011 #23
here's a link for the drives you have.
http://www.denfordata.com/bb/viewtop...1&hilit=parker
07-01-2011 #24
the only sticking point may be the spindle drive, as you'll need to find out what varies the speed and what enables the spindle. Normally there is a relay (SGR, spindle go relay) that enables the spindle, and an isolated 0-10v board that varies the speed.
07-01-2011 #25
I will have a look tommorow to see if I can identify which of these drives I have. Thanks for that. Phil
11-01-2011 #26
I have hard a good look at the circuits in the back of the Starmill. I can't be certain but out of the two types of drive on that Denford link you posted, the sd range looks closest.
I have attached a few pics. On one of the motor boards- PKS Digiplan '87.
The Spindle board is- Jay Electrical DC speed control JE124/1 serial 98712407
The tool change psu 122ve.
I have received parts from Maplin to make buffer but haven't got a clue where to connect up. Phil.
11-01-2011 #27
have a look at the end of the stepper drive boards and it will state what type they are, probably a cd20 or sd 20. Page 23 of the digiplan drive manual shows the pinout for the end connector, and pins 26 and 28 of row c are the dir and clock positions. You'll need to find the wiring that feeds these signals into the drives and isolate them from the main board, then it's simply a matter of putting the buffer board between the breakout boards output and these points
11-01-2011 #28
with the spindle board, do the red orange and brown wires go to a pot for varying the speed.
FOR SALE: Denford Starmill Mach3 Converted
By ricey3 in forum Items For SaleReplies: 2Last Post: 25-11-2013, 03:24 PM -
Dimensions and Weight of Denford Starmill PC Please
By cristec in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-08-2012, 07:02 AM -
FOR SALE: Denford Starmill coverted to Mach3
By Kai in forum Items For SaleReplies: 0Last Post: 02-06-2011, 12:30 PM -
Denford Starmill
By Phil Gravett in forum Computer SoftwareReplies: 6Last Post: 27-05-2009, 12:05 PM
