20-04-2011 #6
The owner said that it had had very little use from him since they've got bigger and better lathes. I tend to believe him since the nut you undo (should be a lever) to rotate the toolpost was extremely hard to undo. I think is the slightly newer version of the old lathe as it's got the later apron and the better bearings.
Re the chuck, small pieces were held and the chucks overtightened so again hardly surprising the jaws are bell mouthed.
Would they be machinable with a carbide tool any plenty of coolant? I read someone doing it on a mini lathe with a diamond tool spinning fast, and the lathe on full speed so the centripetal force pushes the jaws against the thread. That was only to remove a tiny bit though. I guess it's worth a try? Alternatively could I anneal the jaws, machine, then harden again? Just thinking aloud!
I've had the jaws out and there were some burrs on the thread.
Just checked with the indicator and it's the same runout wherever I measure, so must be the chuck at fault. With the indicator on the body of the chuck I get about 0.015mm runout.
Edit:
It's just occured to me, I removed the burrs on the back of the jaws easily enough with a needle file, and somebody's machined them else where which implies that they are machinable. I have a glanze boring bar and some new inserts for it.Last edited by Jonathan; 20-04-2011 at 12:26 AM.
Setting the zero point on a CNC lathe
By Robin2 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 20-10-2013, 10:37 PM -
Colchester Chipmaster Lathe HELP !!!
By snookaman in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 28-08-2013, 10:23 AM -
colchester student 1800 help with knowin what my lathe is capable of
By whensparksfly in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 26-01-2012, 03:30 PM -
By whensparksfly in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 26-01-2012, 01:26 PM -
Colchester Student 1800 Square Head Lathe - HELP !
By cncroger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 03-02-2008, 08:28 PM
