20-05-2011 #4
I see, that's promising. The problem for me is that backlash compensations does not help with the play caused by the backlash. For a rotary axis used with a router or milling machine I think no play is a requirement, otherwise the cutter may vibrate relative to the work-piece? I think is especially true if it's used to rotate the spindle itself, which is my intention. Say there's 100mm from the axis of rotation to the cutter tip, with 19arcmin that's quite a lot of movement: pi*100*19/60/360=0.28mm.
What is the motor input shaft diameter for each of them?
The PLE is the perfect economy alternative to the PLN. We have specifi cally
designed this planetary gear for all applications in which a particularly low backlash
is not necessarily the main focus.Last edited by Jonathan; 20-05-2011 at 11:03 AM.
Rack & Pinion Gearbox/Gearing
By andrewbond in forum Rack & Pinion SystemsReplies: 21Last Post: 12-09-2015, 09:10 AM -
Confirming PSU spec for steppers.
By Rogue in forum Stepper & Servo MotorsReplies: 103Last Post: 13-01-2014, 12:37 AM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Stay with Gearbox or retro fit DC motor etc;
By manofgresley in forum Linear & Rotary MotionReplies: 1Last Post: 06-04-2013, 05:17 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
