    Hi
    This is my first post . I am trying to find out if there is any way that i can run my mach 3 software from my laptop through a usb/parallel bidirectional lead . Or is there a lead or a circuit board that i can buy or make so that i can
    Any help would be greatly appreciated
    A usb to parallel port adapter wont work. You need something like this:
    http://www.planet-cnc.com/
    Or:
    http://www.zappautomation.co.uk/prod...roducts_id=202
    (10% off there at the moment...)
    As you can see it's an expensive way to do it. You save by not needing mach3, but then arguably that's not a saving as you could use the free EMC2 instead.
    A PCI parallel port in the laptop may work ... not sure.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    If you want to use USB and Mach, SmoothStepper from www.warp9td.com is another option.
  4. And Speaking of SmoothStepper i have one that i don't use with extra add-on board for it! if you or anyone else is interested ?
    Quote Originally Posted by AdCNC View Post
    I'm interested in it, 4MHz step frequency is lucrative...
    PM sent
    Another option is the KFLOP from http://dynomotion.com/, which has a Mach3 plugin, however it's nearly $100 more than the SmoothStepper.
    i use ethernet socket as i was advised there is less interference and it is just better by someone with more knowledge than me.
  1. Laptop for CNC Controll
    By Tenson in forum Laptops & Tablets
    Last Post: 15-11-2018, 08:51 PM
  2. Mach3 on Laptop
    By Lovre in forum Artsoft Mach (3 & 4)
    Last Post: 02-01-2013, 05:13 PM
  3. NEW MEMBER: Hi from London - laptop chassis out of aluminium
    By marcosscriven in forum New Member Introductions
    Last Post: 06-04-2009, 08:00 PM
  4. Laptop controller question.
    By m.marino in forum Laptops & Tablets
    Last Post: 07-01-2009, 04:33 PM
  5. Laptop, ie no parallel port?
    By tompsky in forum Laptops & Tablets
    Last Post: 11-11-2008, 07:12 PM
