    I have done the "mechanical work" on a milling machine table to provide two axis control!
    I am now considering the electrics/ electronics!
    Do I need to incorporate limit switches or can I limit the motions in the software ?
    Yes
    John S -
    Robin Hewitt's Avatar
    Lives in Seaford, Sussex, United Kingdom. Current Activity: Viewing NEW MEMBER: Hi everyone Has been a member for 9-10 years. Has a total post count of 1,614. Received thanks 109 times, giving thanks to others 7 times. Is a beta tester for Machinists Network features. Referred 1 members to the community.
    Quote Originally Posted by John11668 View Post
    If you hit a limit switch you have already blown it, fairly useless.
    OTOH homing switches are really useful if you are cutting with jigs.
    Depending on the software/hardware combination you use the Home switches also work as Limit switches after the Homing procedure is complete.
    Ian
    Agreed, I've not bothered with them on mine. I always zero the existing dials before starting off, and check the travel is ok, so if the worst happens I can get it back.
    If you are using servos then you definitely should have them.
    Yes
    Yes I need switches ,
    or Yes I can set the travels limits in software.
    I presume I can also set home in software!!
    If I were to fit home switches I may as well fit the "away" switches too
    Is it permissible to leave switches until I get the software set up or am I likely to crash into end stops.
  1. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  2. stepper acceleration rate - limits?
    By dsc in forum Stepper & Servo Motors
    Last Post: 02-03-2014, 02:25 PM
  3. MY 4`x 4` table
    By Steve-m in forum DIY Plasma Build Logs
    Last Post: 30-10-2012, 12:07 AM
  4. Limits or homing switchs???
    By Ross77 in forum Computer Software
    Last Post: 28-03-2010, 03:17 AM
  5. Tapping holes while material is still clamped to my mill table?
    Last Post: 17-11-2009, 10:30 PM
