30-12-2011 #21
The control software IE: Mach3 handles this side and so long as you don't over tune the motors then it's not usually a problem.
That said PERSONALY I don't like slaving motors for several reasons.!! . . . Main one being that when it does go wrong, which more often than not is at high feeds, the damage thats done can be massive. Imagine the one of the motors stalling coming to a dead stop while the other keeps on going.!! . . .It's like a train wreck and scarey shit, esp on larger machines.!!
To be sure to avoid this you have to effectively de-tune and run slightly lower acceleration/velocity than you can using belts.
There are other reasons like keeping the gantry absolutely square is fiddly to setup and requires good quality accurate home switch's to be absolutely sure it's square every time you home.
Basicly What your doing with the switchs is setting the start point or zero position for each screw and by positioning the switchs you set the gantry square. . . .This is less than ideal to me.!! . . . Mainly because every time you home the machine the gantry gets twisted and co-jolled into square by touching one switch then the other potentially putting strain on the machine.
If you don't use home switch's to square then you can't be absolutly sure the gantry is square and if the motors start dropping the odd step here and there, which can and does happen if you push the machine too hard or over tune motors or it's not perfectly aliagned or setup causing binding.
Basicly it slowly loses position putting the screws out of sync and the gantry out of square.! . . . or if you stop the machine abruptly from high feed one of the motors can slightly run on more than the other due to inertia and position is instantly lost with no easy way to get back in position. . . . With belts this never happens.
Like I say it's a PERSONAL thing and there are lots that use slaved motors and are very happy with them. I've built machines that use slaved motors without any problems.!
It's just MY PERSONAL PREFERENCE to use belts on my own machine because I feel it's safer and more accurate and ounce setup it's pritty much done forgot and never changes.
Yes belts can snap but I've only snapped 1 in 4yrs and that was my fault not belt failure.!
(I'LL SAY IT AGAIN TO STOP ALL YOU SLAVED MOTOR USERS JUMPING ON ME.. . . . . IT'S MY PERSONAL PREFERENCE )
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM -
